front upper wishbone torque setting
Old Sep 16, 2023 | 12:16 PM
Ant Buck's Avatar
Default front upper wishbone torque setting
I removed the upper front wishbone as i wanted to check the bushes and put some copper slip on the parts , the bushes looked like they had been replaced and were fine. What is the torque setting for the bolt? or is just good and tight.
Old Sep 16, 2023 | 03:09 PM
cjd777's Avatar
98-132 Nm on the set of torque specs that I use.
Lower shock mount 6-8- Nm
shock absorber upper stud (non-adaptive damping 30-40 NM. If adaptive damping 16-18 Nm
spring and shock absorber upper-mounting to body (3) 26-34 NM
Old Sep 17, 2023 | 06:20 AM
Ant Buck's Avatar
Thank you for the reply
Johnken
Sep 22, 2021 06:53 PM
Jim D
Nov 9, 2020 09:37 PM
RaceDiagnostics
Mar 19, 2019 02:36 PM
Richxk8
Nov 12, 2017 10:29 AM
MCW739
Jan 27, 2014 04:49 AM
