Fuel filler door latch
Old 11-26-2015, 06:03 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
Default Fuel filler door latch
This little piece of plastic is $40 at the dealer, $20 at SNG Barratt. It slips into the fuel filler door and provides a latch point for the electrically operated pin that locks the door.
Super Glue didn't work. Guess I will have to get the JB Weld out.
Any other solutions?
Old 11-26-2015, 06:19 PM
Gus's Avatar
Gus
Gus is offline
Received 2,208 Likes on 1,700 Posts
Gorilla Glue or a car that is being parted.
Gus
www.jagrepair.com
Old 11-26-2015, 07:15 PM
test point's Avatar
Tried Gorilla Super Glue.
Old 11-26-2015, 07:48 PM
Gus's Avatar
Gus
Gus is offline
Cleaning and leaving the area moist then applying the glue has worked for me. Apparently not a good application for this situation.
Gus
www.jagrepair.com
Old 11-27-2015, 07:10 AM
jamdmyers's Avatar
two part epoxy mix, it will set and it will hold.. never to be removed
Old 11-27-2015, 07:54 AM
mrplow58's Avatar
What Jamdmyers said. There are plenty of 2 part epoxies out there, that will get the job done. They are formulated for about any material you can think of. On the flip side of the coin, as far as Jag parts prices go, $20 isn't such a bad deal. I personally repaired mine with epoxy.......Good Luck.......Mike
Old 12-01-2015, 05:22 PM
julesjag1's Avatar
Probably have one from my parts car. Have to dig for it in my basement. Ten bucks plus shipping.
Let me know, Neil
Old 12-01-2015, 06:00 PM
test point's Avatar
I was able to repair mine with JB Weld off the car. That took some creative effort rather than the seriously permanent 'glue it in place' solution.
The waxed paper separated the side non movable pieces from the center spring attachment clip. Then the side guides were filled with slick nylon like plastic that the JB Weld would not stick to.
Clamping all in place while the JB Weld set was another issue. Got it done and back on. If it fails again I may try something like Elmer's Tack 'N Stik, a non permanent glue it in place option.
gmcgann
11-29-2015 11:42 PM
11-27-2015 08:52 AM
FastCat85
11-25-2015 05:17 PM
Dennis Catone
11-24-2015 04:52 PM
Rhett
11-21-2015 10:23 PM
Quick Reply: Fuel filler door latch
