Fuel filter change
Old Aug 22, 2021 | 09:04 AM
drmike's Avatar
Default Fuel filter change
2000 XK8 fuel filter change. I have done this on an XJ6 and I know some petrol drains down but this time it just kept on coming. I have seen references to 8 oz but I got more like a litre before giving up. I confess I didn't pull the pump fuse and stall the engine so how much fuel should I expect?
Mike
Old Aug 22, 2021 | 09:43 AM
motorcarman's Avatar
I have replaced a few that would not stop dripping and my guess was the check valve?
Work fast and try to keep the fuel out of your arm pits?
Old Aug 23, 2021 | 01:24 AM
Pistnbroke's Avatar
I was planning to do this after finding a new filter in the trunk when I bought it . Thought I might try to find a bolt to fit the threads and then remove the engine side pipe ,fit the bolt to stop the leakage ,fit the front pipe and then do the back quick.
Does anybody know the thread ...everything here in UK is metric.
Old Aug 23, 2021 | 01:38 AM
drmike's Avatar
I think you'll find there is no real pressure so that you may get away with a push on plastic fitting like you get on brake hoses. That's the route I plan to take to buy some time. On the XJ6 there was a lot more give in the pipework so it was easier to get the filter away from the pipes. I think I may also remove the whole clamp fitting which is held on by two captive bolts (I think).
I was baffled as to why it just kept coming.
rockwarrior
F-Pace (X761) / C-X17
Oct 20, 2020 05:34 AM
Johnken
Sep 23, 2018 07:14 AM
bigmatt357
Aug 11, 2014 08:39 PM
Adam Lueb
Oct 14, 2010 04:11 PM
Gunz80
Dec 31, 2008 11:42 AM
