Fuel pump pressure drop under acceleration .... Help
Old Aug 6, 2015 | 01:32 AM
Paulbell's Avatar
Default Fuel pump pressure drop under acceleration .... Help
anyone had a similar problem?
Pump pressure is fine at idling (3.8 bar) but drops to 750 millibar under fast acceleration?..... It's in the garage now.... Waiting for news ..... Sounds expensive!!
Any help appreciated.....
Old Aug 6, 2015 | 01:48 AM
JagV8's Avatar
Blocked filter / failing pump.
Old Aug 6, 2015 | 09:21 AM
WhiteXKR's Avatar
The fuel system was completely changed in 2003, so it is always helpful to put your model year in your signature.
On the later models, there is returnless closed loop electronic regulation of the fuel pressure, so the problem can also be with the electronic pressure sensor or less likely, the ECM.
Old Aug 6, 2015 | 09:37 AM
RCSign's Avatar
Steve correct also the early XKR's have two pumps if one has quit it could effect performance.
Old Aug 6, 2015 | 02:03 PM
plums's Avatar
easiest, cheapest suspect is the fuel filter first before moving on.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
