Fuel tank draining
Old Apr 9, 2014 | 10:49 AM
RJ237's Avatar
Default Fuel tank draining
I have not seen any mention, so I suppose it's not possible, but am wondering if the fuel tank could be emptied by disconnecting filter and using suction pump.
Old Apr 9, 2014 | 02:20 PM
XKRacer's Avatar
The question is why you want to? Otherwise I would disconnect the pipe and let the pump do all the work, I don't think it is possible to suck the fuel out
Old Apr 9, 2014 | 02:30 PM
RJ237's Avatar
Thanks, I was thinking about a fuel pump failure with the tank near full. Not a problem at present, just a what if.
Old Apr 9, 2014 | 02:32 PM
aode06's Avatar
no you can't the check valve prevents fuel from leaving with your method.
Remove the line,front or rear of filter, let the fuel pump do all the work.
Old Apr 9, 2014 | 02:39 PM
RJ237's Avatar
I think I read a post by motorcaman about using wood skids to slide a full tank back to get access to the cover with a failed pump. Looks like that's the best choice. Like I mentioned, just a mental exercise.
Old Apr 10, 2014 | 07:39 AM
Jon89's Avatar
I dread a fuel pump failure in my wife's 2006 XK8 (built in May 2005 so the car will turn nine years old next month). There are numerous tales of failed fuel pumps here on the forum after XK8s/XKRs have sat around untouched for extended periods of time. As a precaution, we have a "three day rule" in place on this car. That means it can sit for no longer than three days without being driven. I hope this rule will greatly extend the life of her XK8's fuel pump....
Old Apr 10, 2014 | 05:13 PM
JajJohn's Avatar
I used a pump for kerosene (battery powered) to pump my tank out cheap and fast.
Old Apr 10, 2014 | 06:53 PM
RJ237's Avatar
That's interesting. How did you do it?
Old Apr 11, 2014 | 05:41 PM
JajJohn's Avatar
I used a pump like this one DuraHeat Battery-Powered Siphon Pump-DH-20 at The Home Depot . I removed the sub woofer and stuck it down in the tank opening (from a post on these forums) and pumped out about 7 gallons. Nice easy clean. I have large hands and couldn't do the tank remove to change pumps. So I had to find an alternative.
Old Apr 11, 2014 | 07:16 PM
RJ237's Avatar
I believe you are writing about the coupe. Several members have changed the pump by using that technique. I was wondering what to do with a full tank in the convertible.
dsnyder586
Dec 29, 2024 07:39 PM
JWheeler
Nov 22, 2019 08:28 AM
Kodiak
F-Pace (X761) / C-X17
28
Jul 24, 2016 02:31 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
