Fuel Trim questions
Old Aug 23, 2018 | 06:36 PM
zray's Avatar
Default Fuel Trim questions
being new to the world of electronic fuel management, I'm trying to catch up on 40 years of engineering advances in a few weeks.
What are the normal numbers for:
1) short term fuel trim
2) long term fuel trim
3) downstream fuel trim
I'm not getting any fault codes, but the numbers are confusing nevertheless.
For short term fuel trim it's consistently under 1% Usually something like -0.79%
for long term fuel trim the numbers are higher, like in the range of -4.50% to -7.0%
But the downstream fuel trim numbers are really high, consistently over -40.0% Do these number have anything to do with the catalytic converter health?
I've looked in the 1999 shop manual I downloaded from this forum (is there a 2002 manual ? I couldn't find it.) And did a few searches here as well. But I think my questions are too basic, and I've come up empty.
thanks,
Z.
Old Aug 23, 2018 | 06:57 PM
here is the link to Gus's website which has some good info on Fuel trims. This should also be in the stickies at the top of the XK8/R forum
JagRepair.com - Jaguar Repair Information Resource
Old Aug 23, 2018 | 09:19 PM
clyons's Avatar
A good place to get started on fuel trims is this thread. I've never heard of 'downstream' fuel trim.
https://www.jaguarforums.com/forum/g...ed-quiz-49317/
Old Aug 23, 2018 | 10:11 PM
zray's Avatar
the code reader I'm using, the icarsoft v1, is a model that is Land Rover / Jaguar specific, and it has "downstream fuel trim" info displayed along with the the other engine module information.
i don't know much about it, hence my questions. But you can goggle downstream fuel trim" and there is some info, but not as complete as I'd like.
Z
Old Aug 24, 2018 | 11:26 AM
alanroberts50's Avatar
Thank you for reposting this link! Wow now I understand the importance of fuel trims and why experienced posters ask for them. I am now going to get mine read in an effort to find out why my cat monitor wont reset.
Old Aug 24, 2018 | 12:01 PM
fmertz's Avatar
Remember, fuel trims are like a 3D elevation map, they are a function of Load and rpm. It is only a single number for a given Load and rpm, e.g. at idle. Off idle, it will likely be a different number. Also likely a different number between idle with transmission in "N" or "D" as the load varies. So posting fuel trims numbers only makes sense if Load and rpm are posted as well (or a shortcut like "idle"). Fortunately, Load and rpm are available over OBDII as well.
Old Aug 24, 2018 | 12:17 PM
JagV8's Avatar
www.onboarddiagnostics.com/page02.htmConsider them with a hot engine (thus also hot cat convs) when parked. At idle ideally they'd all be 0 but that won't happen so somewhere near would be good.
If any LTFT is quite high, rev to about 2500 and see what happens.
With an air leak the LTFT would drop because there's so much more air going in (thus the effect of a leak is far less).
To get a feel for roughly what the PCM (aka ECM) is doing see OnBoardDiagnostics.com - Engine Basics
Old Aug 26, 2018 | 10:54 AM
zray's Avatar
Anyone care to speculate how the use of Techron Fuel treatment will affect the fuel trim numbers ???
Z
Old Aug 26, 2018 | 12:06 PM
RJ237's Avatar
Most of todays fuels have sufficient detergents, so I wouldn't expect to see a change unless the car had been sitting for months or had poor quality fuel. If your highway mileage is below 22 at 75-80 mph it may help.
Old Aug 26, 2018 | 02:55 PM
zray's Avatar
thanks for the post !
I think 22 mpg is too ambitious for an XKR @ 75-80 mph.. maybe a XK-8 does a little better ?
Have just cleaned the TB, intake pipe & mass air sensor. My best is 20 - 21 mpg @ those speeds and using the cruise control. I find it difficult to use the cruise control however. Am afraid of missing out on that great feeling one gets accelerating out of a long sweeper.
Z
Old Aug 26, 2018 | 03:19 PM
Fairfalcon's Avatar
Zray,
I just got back from a 700 mile trip at 75-80 mph most of the way and on board dash shows 26 average MPG in my 97 XK8 conv.
Mike in TN
Old Aug 26, 2018 | 04:32 PM
JagV8's Avatar
Z
Nothing of interest. (Can't see why anyone would care, either, but no matter.)
Don't bother with the stuff but if you are keen on such try BG44K (think I've got the runes right).
Old Aug 27, 2018 | 06:59 PM
zray's Avatar
Originally Posted by Fairfalcon
Zray,
Mike in TN
is that with regular driving or with the cruise control ?
any XKR owners willing to share mpg numbers ?
Z
Old Aug 28, 2018 | 06:07 PM
Fairfalcon's Avatar
Zray,
My drive was without cruise control... and using 87 octane fuel ( the only thing this car has ever used) through the mountains of TN, and now has 113k miles.
Mike in Tn,
Old Aug 28, 2018 | 06:29 PM
zray's Avatar
Zray,
Mike in Tn,
I'm just a tad over 125,000 miles, and have been using 91 octane pure gasoline when I could get it. Does the XK-8 not require the 91 fuel as the XKR does ?
In any case, the only way I'll get above 22 mpg, albeit briefly, is by driving off a cliff.
Z
PS will be driving thru your state on the way to Marietta GA in Sept. Any notorious radar traps to avoid ?
Old Aug 29, 2018 | 05:59 AM
CorStevens's Avatar
at higher altitudes regular octane gasoline can be used in a premium only engine. in the high elevations of Colorado, the sell lower octane than even regular for this reason. it is a premium required car (91 US system) and not using such at sea-level conditions is not the best idea unless one drives very flat roads and does not push the vehicle in the mid-range. speed also makes a big difference in the highway fuel economy. using regular octane, the fuel economy will be slightly lower under all conditions for both energy content (there is a very slightly higher energy content to the octane boosting chemicals, in premium) and engine tune. this all differs from racing fuel in that these fuels are not just higher octane but formulated for higher energy content per unit measure of fuel.
Old Aug 29, 2018 | 06:07 AM
CorStevens's Avatar
regarding Techron Fuel Treatment, very good results if you have the problem of dripping or somewhat clogged fuel injectors. two treatments consecutively made a big difference in performance, fuel economy and idle smoothness. use the larger bottle, add before filing the tank. run down to 1/8 tank and repeat. most additives are a waste of money; this one is definitely worth it.
at 55 with the cruise control, both calculated and dashboard indicated 30 MPG, 28.6 at 70.
Old Aug 29, 2018 | 06:29 AM
Jon89's Avatar
Another vote for Techron here. All of our vehicles get a 20-ounce bottle down the hatch at every oil & filter change interval. It is the only fuel injector cleaner I will purchase. I watch the sales at Advance / Pep Boys / Autozone and grab several bottles when they run their BOGO deals....
Old Aug 29, 2018 | 06:56 AM
zray's Avatar
around here there are 2 formulations of Techron, the fuel injector cleaner, and one labeled "total fuel system cleaner", which I believe is a little stronger, and it costs $ 0.40 cents more than their fuel injector cleaner product. I buy it at Wal-Mart Unfortunately W-Mart does not carry the larger 20 oz. size. But two bottles of the smaller size is still cheaper than the sale price of one 20 oz. bottle priced at the usual Auto Parts stores, So I just dump in 2 bottles every 3rd or 4th tank of (pure) ethanol-free gas. Probably more often than I have to, but I'm trying to clean up the system that may have been neglected by the previous owners.
Z
iilium
Apr 7, 2021 10:26 PM
al_roethlisberger
Aug 7, 2016 02:49 AM
Reb0urne
Jun 22, 2016 04:43 PM
1964Daimler
Aug 28, 2015 06:20 AM
Stu 1986
Oct 4, 2009 08:38 AM
