gas pedal is too high to get comfortable
Old Oct 14, 2013 | 08:04 PM
toronadomike's Avatar
Default gas pedal is too high to get comfortable
I would like to lower my gas pedal so I can relax driving. seems that I'm always holding my foot back and leg up driving my 2001 XKR. does anyone know of kits to lower the gas pedal position?
Thank you,
ToronadoMike
Old Oct 14, 2013 | 08:22 PM
Gus's Avatar
Gus
The gas pedal can be adjusted from under the hood. I am unable to find it so you will need to a search.
Old Oct 15, 2013 | 08:59 AM
Default looking to move assembly forward, not adjust.
Hi Gus,
Thanks for the reply. My under the hood gas pedal/throttle opening adjustment is already optimized. I'm looking to move the entire gas pedal assembly forward an inch and half or so.
Old Oct 15, 2013 | 10:30 AM
RJ237's Avatar
That would be nice, but you would have to move the step down button also, and as you have probably noticed that would require major surgery. I moved my seat back 2" instead, but if you have side airbags that option is not available.
Old Oct 15, 2013 | 04:34 PM
astromorg's Avatar
I too found the pedal positions less than ideal if I had the seat back as far as I wanted, my wife even more so!
My solution was to extend both pedals and the footrest back by two inches. The footrest was done by inserting a couple of lengths of pipe of the right diameter into the existing two large diameter plug/sockets. For the brake pedal, I bolted a suitably dimensioned block of hard wood to the pedal. This was topped off with a curved metal plate of the right thickness and shape to allow the original pedal rubber to fit over it. Finally for the throttle, I machined up a couple of suitable bits of aluminium with a pin on the lower one to replicate the bottom of the throttle lever and the top one suitably shaped to clip into the plastic pedal face. Hopefully the photos will make all this clearer!!
Attached Thumbnails gas pedal is too high to get comfortable-xk8-004.jpg   gas pedal is too high to get comfortable-xk8-005.jpg   gas pedal is too high to get comfortable-xk8-006.jpg
Old Oct 16, 2013 | 04:53 AM
Dennis07's Avatar
Plenty of good ideas and skills in play there. Well done!
JagBrian
Aug 18, 2019 05:07 PM
Russ Graber
Feb 23, 2019 11:59 AM
Horus
Sep 18, 2015 05:39 AM
hen555
Sep 7, 2015 11:13 PM
dcvickers
Sep 2, 2015 06:14 PM
