Green shower from interior lights
Old May 28, 2012 | 06:14 PM
tberry6686's Avatar
Unhappy Green shower from interior lights
Hi Guys. Just got a green shower from the centre interior lights when I tried to lower the roof.
I have found out that it is the hydraulick fluid from the roof so probably a hose has let go.
Anyone have any idea of which hose it will be as I will have to fix it within 1 day due to no garage to leave the car in overnight and I don't fancy leaving the roof open around here ?
Would it be better just to replace all the hoses as it is likely they are all the same age ans so if one has failed then the others may well be a bit below par now ?
One more question - does anyone know how much fluid the system needs for complete fluid replacement - can't find the info anywhere in the manuals and at £15 per litre don't want to get to much - already looking like a £700 repair job.
Old May 28, 2012 | 06:27 PM
Hare's Avatar
I believe the hoses come together in a kit and one quart of fluid is all that is needed.
Old May 28, 2012 | 06:37 PM
tberry6686's Avatar
I'm in the UK. So far all I have been able to find for the hoses is one supplier at a mouth watering £600 for all three. Any info on a cheaper supplier would be most appreciated.
Old May 28, 2012 | 07:08 PM
motorcarman's Avatar
The dealer I get parts from charges less that $300 USD for part number HJB8256AB (hood latch hose set) Wholesale Price.
You can buy PENTOSIN CHF11S fluid in one liter containers for around $20 USD here in North America.
Do search for the Jaguar part number HJB8256AB.
bob gauff
Old May 28, 2012 | 07:52 PM
WhiteXKR's Avatar
The other hoses do not fail nearly as often as the top latch hoses...just replace the top ones.
Old May 28, 2012 | 08:30 PM
xenophobe's Avatar
Consider getting the aftermarket hose kit from Colliflower. It's so heavy duty, it will never fail. It's also about the same price as the OEM hoses from Jaguar and the installation is identical, except you need to replace the fittings, which the kit comes with.
Old May 28, 2012 | 08:44 PM
scottatl's Avatar
here is the link for the Colliflower. It is a big job to replace. I hd my Jag shop do it for me, what a bummer.
JagRepair.com - Jaguar Repair Information Resource
Old May 29, 2012 | 12:13 AM
Super Cat's Avatar
See www.jagrepair .com for lots of information about the hoses etc.
Old May 29, 2012 | 07:18 AM
BlkCat's Avatar
Scott,
Which Atlanta shop did the work? I am in Atlanta and want to keep this in mind if/when I need new hoses.
Do you recommend the shop for all repair/maintenance? I am currently under Jag warrantee and let them do anything the car needs. But when this runs out...
Thank you,
Jack
Old May 29, 2012 | 09:15 AM
Hare's Avatar
I just replaced mine and it took me around 7 hours to complete. Keep in mind that I took my time and had to re-read lots on account of not wanting to damage any fascias. Could do it now in around 3-4 hours
Old May 29, 2012 | 03:37 PM
Spurlee's Avatar
I recommend Collifolwer hoses - very high quality at the same price as OEM or less. Also, consider rebuilding the top latch while you have it out. $150 at Top Hydraulics.
Old May 29, 2012 | 06:21 PM
xenophobe's Avatar
Oh wow, there's a place that rebuilds them? That's new news to me.
Old May 29, 2012 | 07:57 PM
Spurlee's Avatar
Yes. Top Hydraulics | Rebuilt Convertible Top Hydraulic Cylinders - Top Hydraulics, Inc
Klaus is a great guy, and has experience in rebuilding top latch systems for a variety of cars. He just started rebuilding XK8 latches.
It took about 4 or 5 days - including shipping - to have mine rebuilt. He might have some in-stock units by now. $150
My latch started leaking shortly after I replaced the hoses and I had to remove and reclean everything twice. When you start the hose project, remove the latch first, send it out and you'll and get it back just about the time you are back to that point...
Old May 29, 2012 | 08:59 PM
xenophobe's Avatar
That's good to know. If I had known, I would have sent mine out just for self assurance.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
joseph1945
Sep 5, 2015 07:12 PM
King Charles
Sep 3, 2015 12:40 AM
