Head light washers
Old Oct 19, 2015 | 03:18 PM
bcucharternet's Avatar
Default Head light washers
Did all 2000 XK8's come with the headlight washer assembly?
Old Oct 19, 2015 | 04:51 PM
max224's Avatar
Don't know, but mine has them.
Old Oct 19, 2015 | 05:23 PM
brgjag's Avatar
Most likely.
Old Oct 19, 2015 | 05:46 PM
Default Head Light Washers
I just purchased an XK8 and when I turn on my windshield wipers the headlight washers do nothing. Is their a separate switch to activate them? Is there a separate fuse for them?
Thank you
Old Oct 19, 2015 | 05:49 PM
rttug's Avatar
My 2000 xk8 does not have them
Old Oct 19, 2015 | 06:15 PM
Default Headlight Washers
How do you know if your XK8 has headlight washers or not ? or if they simply aren't working ?
Old Oct 19, 2015 | 06:52 PM
DaveInVA's Avatar
My '97 has them but a previous owner disabled them but thats fine with me,
Dave
Old Oct 20, 2015 | 06:15 AM
reb1999's Avatar
Default Auto
My '99 has them/. Did not see an option for them so I would expect they were standard.
Operation. Work with the wind screen washers. I had to replace the chrome/ glass cover in the lower section of the headlight when I first purchased my XK8. The washer unit pushes out word to function. I would guess they work for some users. Seems a little strange to me. Rich
Thank you
Old Oct 20, 2015 | 08:34 AM
Angus's Avatar
If I remember correctly, the headlamp washers operate on every 5th or 6th use of the screen washers.
Old Oct 23, 2015 | 09:05 PM
Jag#4's Avatar
+1, but I think it is sooner than that. 3 or 4?
BTW, they can be annoying, so some owners pull the fuse. I did. If they don't work after at least 10 tries, take a look at the fuse.
Old Oct 24, 2015 | 11:00 AM
mrplow58's Avatar
What makes the headlight washers extend?......My right one works, but the left one stays in. Is it pressure, or an electric motor......Thanks....Mike
tylerh860
Nov 17, 2015 10:14 AM
steelcowboy
26
Oct 22, 2015 11:11 AM
Toney6211
Oct 19, 2015 03:16 PM
Cody04XJ8
Oct 18, 2015 05:19 PM
Jag Princess 1
Oct 17, 2015 08:37 PM
