Headlight rainwater deflector installation tips?
Old Sep 21, 2022 | 05:45 PM
crvols's Avatar
Default Headlight rainwater deflector installation tips?
I have a recent,y acquired 2006 coupe and noticed it did not have the headlight water deflectors I see on other cars. I purchased a used pair but cannot seem to fit them to my car? Can anyone tell me how they should fit?
Old Sep 22, 2022 | 12:57 AM
Pistnbroke's Avatar
If its the part I think you mean one end just pushes under the end of the wing..under the strip where its bolted down (its like a trough that shoots the water over the lamp right? )
Old Sep 22, 2022 | 03:55 AM
PKWise's Avatar
As Pistnbroke describes, do you mean the 'Water Shedder' as shown in this video from 3min 38sec to 4min 47sec ?
Old Sep 22, 2022 | 06:32 AM
SamtheSham's Avatar
They may have been removed to facilitate moisture evaporation.
Old Sep 22, 2022 | 06:42 AM
Pistnbroke's Avatar
Sam sham ..I dont see that as the vents into the headlamps are on the side.
Old Sep 22, 2022 | 06:56 AM
SamtheSham's Avatar
I did not see which vents he was referencing. My Rt. side light get water accumulation during rains. I removed the top 'oval' cover per someone in this forum and now the moisture clears very quickly.
Old Sep 23, 2022 | 01:35 AM
Pistnbroke's Avatar
Having the top out is a bad idea. What you need are the water shoots and the oval lid fitting properly. I keep mine pushed down with a small block of wood about 3/4 thick under the body member that passes over the unit and have silica jell inside the unit ..no problem for 18 months
Old Sep 23, 2022 | 06:53 AM
crvols's Avatar
Large silicone packs, close lid, no moisture after driving in rain forc1.5 hours.
Old Sep 23, 2022 | 08:49 AM
Pistnbroke's Avatar
This is how you want it ...closed off ...rain shoots and silicone jell ...photo attached .
If you let water in then the silvered surfaces corrode and you dont pass your roadworth test .
Bob Boyle
Jan 30, 2022 11:09 AM
NYCJAG2006
Apr 30, 2020 02:10 PM
o2manyfish
Feb 26, 2018 12:25 PM
Alan E L
Aug 11, 2013 10:00 AM
