Help! 2001 XK8 Convertable Top Problem
Old Nov 2, 2009 | 01:34 PM
H20boy's Avatar
saw your new thread was in the XJ section, so moved it here for you Mike.
BTW, In order to close the top, you must be <10mph, thats a safety/damage prevention thing
Sounds like you buggered something really good. There's a manual closing procedure, I don't have it with me now, but maybe someone will come along and give it to you.
Old Nov 2, 2009 | 01:45 PM
Gus's Avatar
Gus
Go over to my page and I have 3 locations relating to the roof operation. Select the Hydraulic Hose Evaluation first. It also has a TSB on troubleshooting. Now if you are going to drive the car you will need to latch your roof properly so it does not catch the air and it comes off completely.
Old Nov 2, 2009 | 02:44 PM
Gus's Avatar
Gus
After reading your post you may be lucky and just confused the system like h2o is suggesting. All the switches and operation go to the body processer and it may need to be satisfied or reset. At times using the wrench in the trunk pump area to latch the roof up front may satisfy the system in thinking it is properly closed. You will know this if your windows go up after closing the front latch manually. I would recommend doing the electrical close of the windows with the roof close button. If the windows close then cycle the entire system to open and then close again and you should be ok. If it does not let us know. It may require opening the roof manually and that is a little tricky if the lifts are extended properly or disconnecting and reconnecting the battery terminal.
Old Nov 2, 2009 | 05:17 PM
SeismicGuy's Avatar
Something that sounds similar happened to me a few times. In my case, as the top was coming up the latch mechanism got hung up. Consequently, the top did not latch (also got a fault message) and nothing worked at that point. I had to go through the manual operation (release the pressure at the pump by turning the ****, pardon the expression) and use the wrench to latch the top. Then I closed the **** and the top operated just fine. I discovered the latching mechanism could use a few shots of WD-40 (or some other grease) every so often to prevent binding.
Doug
Old Nov 2, 2009 | 07:36 PM
Gus's Avatar
Gus
I can agree with Doug on the latch thing and lubrication does seem to be a problem. WD40 will work however, I have my preferences. Give it a try but tell us what worked…
Old Nov 3, 2009 | 02:02 PM
walt_00XKRConv's Avatar
Default Also check the oil
You should definitely check the oil level. My problems like this all resolved back to the pump sucking air instead of oil. This could be as simple as sitting on a down grade or a slow leak in one of the cylinders. When the roof goes up the oil is at the lowest level because the lift cylinders must be filled. This will result in the roof stopping short of the latch. The mechanism grinds to a halt and can't move forward and won't move back either because it is still trying to finish the first operation.
When a cycle does not complete the Jaguar Tech Bulletin says to hold the button for 40 seconds. This causes the control to time out and not be lost in the middle of an incomplete sequence. Manually closing will also accomplish the same purpose. The control is waiting on switches that indicate that the roof is in position and the latch is closed.
Old Nov 3, 2009 | 03:15 PM
mbalce's Avatar
Gus,
What have you found is the best lubricant for the top latch?
Thanks,
Old Nov 3, 2009 | 03:35 PM
Gus's Avatar
Gus
I like WD40 for a number of reasons but for a lubricant that will withstand high and low temperatures and not lose its consistency I use Pennzoil 705 white grease. It has a high melting point and it is water resistant. It exceeds most lubrication qualities with 1 exception, a lubricant made by corning and that is out of my price range.
Use the WD40 and see if it frees up the latch. If it does make it operate better you may want to fallow up with the white grease. When applying use a thin layer on a clean surface, WD40 is a good produce but does not last nearly as long as the white grease.
Old Nov 3, 2009 | 05:46 PM
SeismicGuy's Avatar
From research prior to buying and my own experience since owning, it seems like these cars are subject to occasional irritating electrical gremlins. My understanding based on reading a book on the XK8 by Nigel Thorley is that this car was one of the first attempts to use multiplexing throughout the electrical system. I believe this means that the same line could be used for multiple purposes and different signals going through the line could be destined for different systems (I am a structural and not an electrical engineer so I probably described this poorly). According to the book, this also makes it difficult to track down electrical problems.
Doug
Old Nov 3, 2009 | 05:52 PM
Gus's Avatar
Gus
I am glad you got it corrected. You miss your BMW “Ouch”!
Old Nov 4, 2009 | 08:53 PM
test point's Avatar
JTIS, the complete manual on the entire Jaguar product line from about '95 until '03 is available on this forum. It contains all the wiring diagrams.
Check here:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
jdzubas
Oct 4, 2015 09:14 AM
msdg137
Sep 16, 2015 06:24 AM
reedmtn
Sep 5, 2015 08:04 AM
tony bosco
Sep 1, 2015 02:06 PM
Jandreu
Aug 29, 2015 07:31 PM
