Help with finding a small retaining clip - RESOLVED
Old May 8, 2021 | 10:54 AM
Barry_Tucker's Avatar
Default Help with finding a small retaining clip - RESOLVED
I did my valley hoses and am reassembling everything. There is a hose that is surrounded by a foil coated shield ( lots of the foil is gone ) that comes from right side fender and plugs in right under the throttle body ( I don't know what the hose is called ) There is clip-retainer that holds the hose in place where it plugs in. The retainer / clip thing has gone missing I don't know what it's called so I have no idea how to order it.
Can anyone shed some light please ?
Last edited by GGG; May 9, 2021 at 05:06 AM. Reason: Add "RESOLVED" to thread title
Old May 8, 2021 | 11:01 AM
BobRoy's Avatar
You should only need replace the oring and black plastic piece.
Old May 8, 2021 | 07:05 PM
Thanks very much
Old May 9, 2021 | 06:44 AM
RaceDiagnostics's Avatar
I ended up losing that retaining clip too, in the end I used some high temp silicon to "glue" it in place and ensure there was no vac leak.
Old May 9, 2021 | 01:26 PM
to BobRoy or some other more knowledgeable than I ...Do you have a part number for the foil coated sleeve/shield as well. if i am going to order the kit , might as well replace the sleeve and make it look a bit better too
Old May 9, 2021 | 02:09 PM
BobRoy's Avatar
Sorry I don't know.
You can use your own insulating material . I think the reason for the sleeve is to protect the plastic tube from the heat of the nearby exhaust manifold. I see no reason you can't design your own with an insulating material that appeals to you aesthetically.
Old May 9, 2021 | 04:12 PM
Thanks ...it would just be easier to buy off the shelf
Old May 9, 2021 | 09:34 PM
BobRoy's Avatar
Barry,
I think this is what you are looking for. This is at Jagbits. You can use the part # to search elsewhere.
PROTECTIVE SLEEVE FOR BRAKE VACUUM PIPE XR834015
Not Yet Rated | Write the First Review
Fits: Jaguar 1997-1999 XK8
Part Number: XR834015
Price: $84.02
Good luck,
Bob
Old May 10, 2021 | 07:24 AM
Thanks again
Old May 10, 2021 | 09:58 AM
MRomanik's Avatar
Veteran: Air Force
I purchased insulation sleeves at an auto parts store (can't remember which one) several yrs ago when I replaced the PS lines.
RDMinor
22
Nov 10, 2022 08:47 AM
Greg in France
Apr 2, 2020 07:34 AM
p-Rock
Aug 31, 2017 08:36 AM
dennysjag
Mar 6, 2016 08:04 PM
tjlascek
Aug 6, 2013 09:00 AM
