Help.....Gauges on Dash Giving false Readings
Old Dec 23, 2015 | 02:51 PM
kevjag65's Avatar
Default Help.....Gauges on Dash Giving false Readings
I have a 2001 XKR (51PLATE), all of the gauges apart from the rev counter is giving false readings. Im doing approx. 70mph and the gauge is showing 130mph.
The fuel gauge Is showing approx 60miles of fuel in but the digital display is showing 300+
Temp gauge similar, any feedback on what the fault is or how to fix,
Old Dec 24, 2015 | 01:08 AM
JagV8's Avatar
You've more chance if this is moved to the right forum
Old Dec 24, 2015 | 02:06 AM
Welcome to the forum kevjag65,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Dec 24, 2015 | 06:21 AM
RJ237's Avatar
Are you sure it's not reading in KM?
Old Dec 24, 2015 | 09:52 AM
kevjag65's Avatar
HI i've checked that ,for some reasone the car was parked up 1 to 2 weeks ,I don't use it that often, jumped in car 2 miles down the road gauges reading wrong ?
Old Dec 24, 2015 | 09:55 AM
jimbov8's Avatar
Bingo. Try fully charging the battery overnight and then try again.
Old Dec 24, 2015 | 11:22 AM
kevjag65's Avatar
battery fully charged done that ,gut instinct says clock cluster faulty maybe? but I don't want to go there if someone on here has had similar fault
Old Dec 24, 2015 | 11:30 AM
jimbov8's Avatar
You may well be right, have you tried the hard reset?
Old Dec 24, 2015 | 12:57 PM
kevjag65's Avatar
Thanks for the advice will check it out after xmas
Old Dec 24, 2015 | 01:02 PM
WhiteXKR's Avatar
This could happen if your battery died and you recharged or jump started. The gauges are stepper motors controlled by a computer. The data registers which contain the zero position and the scaling factors that control the movement of the gauges can be corrupted by low battery voltage.
A hard reset, or simply disconnecting your battery for about a minute, then reconnecting, it will allow the system to reinitialize and should solve the problem.
Old Dec 24, 2015 | 01:52 PM
kevjag65's Avatar
Thanks for the info I;ve tried the battery disconnecting it still the same ,next thing hard reset ,?
Old Jan 1, 2016 | 12:50 PM
kevjag65's Avatar
I've bit the bullet and bought a new battery (the other one was tested and showing as ok) however the car is still playing up- the gauges are all over the place- false readings. It's ok when it's cold but changes after 2-3 miles. It is charging fine. Any other suggestions would be greatly appreciated (or anywhere I can send the clocks to be tested),many thanks
Old Jan 2, 2016 | 03:51 AM
JagV8's Avatar
Grab electrical guide from workshop manual (free download) and look hard hoping for ideas about bad ... wiring? something else? ...
Hafrod
Dec 30, 2015 08:22 PM
Fstbmw1
Dec 27, 2015 09:57 PM
jagnew
Dec 23, 2015 09:17 PM
Brucey
E type ( XK-E )
Dec 7, 2015 09:18 AM
kevinamon
Nov 24, 2015 03:09 AM
