Help identifying powersteering part #
Old Oct 30, 2013 | 09:57 AM
lunaticpro's Avatar
Default Help identifying powersteering part #
Just upgraded my exhaust system and was having fun with the boys taking the corners with the added boost and then it happened.. power steering pump went dry and began to make noise. So now I need to replace but problem is that the 97 year model had two different pumps.. Mine is gonna be the one prior to the upgrade which i found to be
MJA8111BH - XK8 97 from VIN 016230
Can anyone identify the one used for VINs prior to the mentioned above?
Old Oct 30, 2013 | 10:31 AM
The Coupe's Avatar
Continue your investigation but I would think that the upgraded pump would work just fine for your car.
Old Oct 30, 2013 | 10:33 AM
aode06's Avatar
The dealer will give you the part number with your vin-parts dept
Old Oct 30, 2013 | 10:51 AM
From the Parts Catalogue:
Original Pump MJA 8111BF was superseded by MJA8111BG. Both of these are shown as No Longer Available and have in turn been superseded by MJA8111BH.
Old Oct 30, 2013 | 11:23 AM
lunaticpro's Avatar
Thanks guys. Wasnt sure... Im guessing then MJA8111BH will work regardless. Appreciate it...!!!!
Old Oct 31, 2013 | 07:03 AM
aode06's Avatar
If you have access to a air blow gun, id flush the fluid as well. Really preserves the pumps life.
aholbro1
Dec 29, 2024 06:46 PM
JarodL
Mar 7, 2024 01:39 AM
trosty
26
Dec 18, 2022 06:40 PM
Scott B
Oct 24, 2015 01:29 PM
TC Johnson
Sep 2, 2015 09:30 AM
