help with restricted performance issue
Old Oct 14, 2014 | 07:13 AM
xk8lattmaster's Avatar
Default help with restricted performance issue
I have a 2001 xk8, engine lite and "Restricted Performance" lite keeps coming on. Had valves cleaned of oil and new spark plugs, after about 20 miles, it happened again.
Have you ever had this problem?
Thanks,
RL
Old Oct 14, 2014 | 09:31 AM
Rich - I've moved your question to its own thread so it gets visibility to assist with the problem.
First thing I recommend is getting the codes read then post here for guidance. Most Advance Auto or Autozones can read the codes for you.
regards,
steve
Old Oct 15, 2014 | 02:37 AM
JagV8's Avatar
Maybe the battery is failing.
Old Oct 15, 2014 | 07:21 AM
why would the battery have anything to do with the engine lite on and running ruff?
Old Oct 15, 2014 | 08:15 AM
weak battery doesn't provide sufficient voltage for the sensors leading to spurious warnings, etc.
If you take to Advance Auto, they can test the battery and charging system as well as pull codes. Once you have this done, post results here and we can go from there
Old Oct 15, 2014 | 02:31 PM
O.K.
I understand, will do as you suggest. I will post the results as soon as I can.
Thank you,
Rich
Old Oct 15, 2014 | 03:51 PM
Gus's Avatar
Gus
Get a reading on the OBDII and post the codes also get the battery checked as suggested the xk8 does not like low voltages or fluctuation. Also did you do a hard reset after all your work on the car?
Old Oct 16, 2014 | 07:23 AM
Unhappy
went to Advance Auto yesterday afternoon, they checked the battery, 12.5 volts
They could not find a place to plug in the code reader, she said that it might be under a door that had about 4 screws in it. So, no codes
PS - what is a hard reset, guess I didn't have it done
Restricted Performance light was out last nite, only the engine light was on.
after about 15 miles, on the way home from Advance, the Restricted Performance light came on again, and the engine lost power, skipped and burped.
I guess I need a Jaguar mechanic, local mechanics only do a few things and charge me $340.00 dollars. Light still on.
Old Oct 16, 2014 | 07:42 AM
the OBD port is on the drivers side under the dash to the left of the steering wheel (right up against the door).
Here is a link to a previous thread where Graham provides a nice picture of its location
https://www.jaguarforums.com/forum/x...cation-128596/
Old Oct 16, 2014 | 08:01 AM
here is the link to the hard reset
https://www.jaguarforums.com/forum/x...ect-faq-74146/
Old Oct 20, 2014 | 08:35 AM
Just bought a code reader on line. Will post codes when I receive it.
Still having restricted performance problems.
OK, what happens when I read the codes, how do I know what they mean?
Thanks,
Old Oct 20, 2014 | 08:42 AM
if you go to the very first page of the XK8/XKR section, the first few threads contain some excellent resources including some how to's:
https://www.jaguarforums.com/forum/x...ts-data-29800/
open the above link and about 3/4ths the way down the page there is alink to OBD codes
http://www.jagrepair.com/DTCforms/X1...C_OBDII_R1.pdf
You can also go to Gus's site - Jagrepairs.com - the link to the OBD codes is below:
JagRepair.com - Jaguar Repair Information Resource
Old Oct 20, 2014 | 08:45 AM
aode06's Avatar
Why buy a OBD reader online, you could of bought one at any auto parts store.
I would go autozone, show them the location of the obd port,they will print the codes, simply post here to us.
Keep your new reader when it comes in the mail.
Old Oct 21, 2014 | 07:14 AM
EBAY is much cheaper, plus free shipping.
Went to Advance Auto, they could not find the OBD port.
I will, however, try Autozone.
Thank you,
Old Oct 24, 2014 | 06:08 PM
johns427's Avatar
Rich, I have that light on also. No codes are registered, so I have no clue. Let us know what you find.
Old Oct 24, 2014 | 08:15 PM
RJ237's Avatar
Thank you,[/QUOTE]
It's right above the hood ( bonnet) release.
Old Oct 25, 2014 | 10:12 AM
Default Restricted Performance
Got the code reader, didn't use, went to Amesbury Foreign Auto this morniing.
It was running good at that point, only the Engine light was on, not the Restricted Performance light. So he read the codes, didn't tell me the codes, but said the reader told him the number 2 valve was the culprit. But it was running great, so he reset the engine light and all was fine. For about 10 miles, the the Restricted Performance light came on again, but not the Engine light. Can't figure it out. I guess I will have to have a mechanic keep it for a while to figure out what is really wrong. Does not run as smooth as it did 2 hours ago. Any ideas ?
Old Oct 25, 2014 | 10:25 AM
Gus's Avatar
Gus
Get the code not what you think it means and post it.
Old Oct 25, 2014 | 10:29 AM
DaveInVA's Avatar
Try taking the coil access covers off and examine the cabling and the plug-ins on the coils. Look for signs of moisture and condensation. Try cleaning the coil connectors but be careful as the plastic gets very brittle and its easy to break the holes out that the release clips slide into.
Dave
Old Oct 25, 2014 | 03:26 PM
RJ237's Avatar
Just post the codes here, like almost everyone keeps telling you.
