High Pitch Whine in Engine Compartment... any ideas?
Old Sep 17, 2011 | 02:16 AM
xenophobe's Avatar
Default High Pitch Whine in Engine Compartment... any ideas?
First off, I am not a mechanic.
There is a new high pitch whine, similar in sound to my Chevy Suburban's fuel pump. It's coming from the engine compartment, from the best I can tell, it's behind the supercharger around where the distributor should be.
The whine is pretty much constant. It does change pitch going from park to drive, but revving the engine or driving it does not really change the noise as far as I can tell.
It's going to the shop on monday anyways, but any ideas of what it is?
Old Sep 17, 2011 | 08:04 PM
xenophobe's Avatar
Wow, not a single response :\
Old Sep 17, 2011 | 10:48 PM
Reverend Sam's Avatar
It sounds like my ex-wife might be in your engine compartment.
Old Sep 18, 2011 | 12:56 AM
avos's Avatar
It could be a couple of things, but I can't see the point of guessing to be honest, especially not when you bring your car, as for a good technician it is easy to spot. A recording would have helped though.
Old Sep 18, 2011 | 03:08 AM
Frog's Avatar
Old Sep 18, 2011 | 10:23 AM
Jochem00's Avatar
There is no distributor.
Anyway, the whining noise comes from your acc. Belt.
Easy to replace
Old Sep 18, 2011 | 05:03 PM
xenophobe's Avatar
Easy to replace
Sorry, was having a bad day...
Old Sep 18, 2011 | 07:15 PM
80sRule's Avatar
It may be the throttle body. They make some noise even when the key is just in the on position. Try the key to on, with the engine off and see if that's the noise you're talking about.
Old Sep 19, 2011 | 01:27 PM
H20boy's Avatar
Agree with 80sRule (which they do BTW, totally). Then again, it could be the climate control. Either way, its normal, and should not be of any concern. If you hear crazy ticking from your driver fenderwell, then I CAN tell you what that is.
Old Sep 19, 2011 | 02:50 PM
malbec's Avatar
Well if it wasn't Rev SAMs ex then it could be this
BBC News - Cat travels 17 miles under car bonnet into Aberdeen
Quite appropriate for a Jaguar
Old Sep 28, 2011 | 11:20 PM
xenophobe's Avatar
Problem solved... it was this thing:
It was the first time my indie shop had ever seen this go bad, and Jaguar no longer stocks this part so I had to get a used one:
Old Sep 29, 2011 | 06:29 AM
What is it?
Old Sep 29, 2011 | 07:17 AM
XKRacer's Avatar
Its a supercharger bypass actuator
Old Sep 29, 2011 | 09:59 AM
Mountaincat's Avatar
What in the heck does it do? Wow Jag. doesn't carry this part for a 2005 MY---hard to believe! Maybe it's special order?
Old Sep 21, 2015 | 02:41 AM
pk4144's Avatar
XENOPHOBE, I am very late to this post but I am having the exact same problem! Just bought a 2011 XKR converible. What exactly was the fix??
Old Sep 21, 2015 | 04:09 AM
JagV8's Avatar
Sounds like it's the solenoid-activated flap that's open except when on boost. Wreckers should have one.
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
