How to add xk8 convertible top hydraulic fluid
Old Jan 13, 2013 | 04:09 PM
scezlivin's Avatar
Default How to add xk8 convertible top hydraulic fluid
Hello,
I have been searching and I seem to find everything about the convertible hydraulic system except how to add fluid. I know where the cylinder is located but see no way to add.
Robert
Old Jan 13, 2013 | 04:23 PM
Gus's Avatar
Gus
The tank is located to the right of the trunk just above the CD player you will need to remove the panel covering it. The pump and tank are attached and the fill is a plug at the top of the tank. It can be filled without removing it from the rack but you will need a syringe with a tube to fill it JagRepair.com - Jaguar Repair Information Resource
99xk8guy
Sep 29, 2025 10:51 PM
kelliott
May 31, 2022 05:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
sogood
Sep 15, 2015 07:35 AM
obwoodie
Sep 3, 2015 07:45 PM
