How Many Tons for a Ball Joint Press?
Old Nov 14, 2010 | 11:26 AM
Reverend Sam's Avatar
Default How Many Tons for a Ball Joint Press?
Harbor Freight has this press for only $100:
http://www.harborfreight.com/6-ton-shop-press-4711.html
It's only 6 tons though. Is that enough to press out old ball joints and press in new ones?
Old Nov 14, 2010 | 12:44 PM
test point's Avatar
From previous discussions seems that 20 tons is more in line with requirements. Several comments on the difficulty pressing them out. You aren't going to use this repair and photo shoot as an excuse to buy another tool are you?
Old Nov 14, 2010 | 02:38 PM
steve11's Avatar
ud
Sam, I agree with Test. I've had access to a 20 ton press when I've done these. Not saying anything less will not work, but you'll be closer to 20 than 6. If you start spending too much money on the press for just a one-off, you might consider just buying the whole assembly.
Old Nov 14, 2010 | 02:46 PM
XKRacer's Avatar
I have had no problem doing ball joints on just a 2 ton press so IMO I dont think you will have a problem
Old Nov 14, 2010 | 02:47 PM
Martin's Avatar
steve11 has the right idea. Presses have been known to be unsage too.
Old Nov 14, 2010 | 02:50 PM
XKRacer's Avatar
I will also say I have done them in just a vice also, but that was a big vice and you do not need to press them back in they just need a tap with a sleeve and hammer, I have a spare lower wishbone in the shop I might just show you how I did it, it is quite simple.
Old Nov 14, 2010 | 03:35 PM
steve11's Avatar
ud
I will retract then as I've never had to do these without access to the 20 ton press I have. Maybe something a lot lighter can get the job done for you then.
Old Nov 14, 2010 | 04:00 PM
Dan R's Avatar
I am hoping to use an OEM ball joint press rented from Autozone to do the job. From the boards, it seems to be sturdy enough, unlike the Harbor Freight versions.
Old Nov 14, 2010 | 04:14 PM
test point's Avatar
I bent the rent 'C' clamp from Advance AP pushing the wishbone bushings out of a Volvo.
Old Nov 14, 2010 | 11:57 PM
avos's Avatar
I have only done bushings on my car, and am sure I never saw my press (20ton) go over 5ton on the meter, no guarantees though it will never do.
Old Nov 15, 2010 | 06:40 PM
I went to Harbor Freight today with a 20% off coupon in my hand. They had a 12 ton press on sale for $129. With my coupon the total price was $103 plus tax. Here's the one I got:
Hopefully 12 tons will be enough. Now I need to find someplace to hide a 12 ton floor press where my wife won't notice it.
Old Nov 16, 2010 | 11:34 AM
Dan R's Avatar
He with the most toys wins!
You can use it to replace the lower control arm bushes while you're at it. This press looks very similar to one a local garage used to press in bushings.
Old Nov 16, 2010 | 11:48 AM
Yep, that's why I bought it right now. I don't even have replacement ball joints yet. If I did I would do them at the same time.
...hey, now that I think about it, I oughta just go ahead and buy the ball joints and do them at the same time I do the lower bushings. Judging from what I've seen in the JTIS, the lower control arms are going to be a lot more difficult to remove.
TreVoRTasmin
Feb 23, 2021 03:13 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
JagBrian
Oct 1, 2015 12:52 AM
JAMES1944
Sep 29, 2015 11:58 AM
Camnelson324
Sep 27, 2015 08:48 AM
