How to recover back of floor mats
Old Jan 18, 2016 | 07:48 PM
brgjag's Avatar
Default How to recover back of floor mats
I pulled some orig xk8 floor mats that will work great in mine. Problem is that they sat in water in the car for some time through the years it appears and the backs of them are in various states of falling off. They never were rubber coated like most are in cars. It is/was some type of black material covering.
Anyone have any idea what I can use on the back of them to seal them back up. Any kind of spray that when dry would seal them but not just fray back off onto the carpets after a few drives in the car? Maybe put new cloth on them and glue that to the back?
Old Jan 18, 2016 | 10:27 PM
XxSlowpokexX's Avatar
Maybe have some cloth sewn on the back. Matts in my xkr are deteriorating in much the same way
Old Jan 19, 2016 | 08:11 AM
Jon89's Avatar
Go to your local fabric store and ask to see their selection of waterproofed fabric. Pick a heavy-duty weave that has been infused with a rubberized coating. Get a small can of brush-on contact cement. Once your old mats are thoroughly dry, use them as your template to cut the backing fabric into the proper shape. Then use generous amounts of contact cement to attach the backing fabric to the underside of your mats. Once the two pieces are lined up and pressed together, lay them on a flat surface, cover them with a sufficiently-sized piece of plywood, and set heavy objects all across the plywood to ensure a consistent bond. I would allow them to cure that way for at least three or four days before placing them in the car just to cut down on the glue fumes you'll have to put up with for awhile....
Old Jan 19, 2016 | 10:03 AM
Rick L's Avatar
I wonder of you could use a can of Flex-Seal. It comes in black or white. t is a spray on plastic. The add shows them coating a screen door and then floating on it. I have used it to line garbage cans and to seal pinhole leaks in vacuums. I think it would bond well and seal the back. Just a thought.
Old Jan 19, 2016 | 10:57 AM
brgjag's Avatar
that sounds good. Where can I get that? Based on the name it is flexible.
Old Jan 19, 2016 | 11:04 AM
Rick L's Avatar
I got mine at the local ACE hardware store.
Old Jan 21, 2016 | 12:10 PM
I suppose that would at the very least encapsulate all that fuzzy mess from getting everywhere
Old Feb 24, 2016 | 05:26 PM
brgjag's Avatar
I used the flex seal but the stuff STINKS. ha ha ha. Smells (strong) like tar almost a week since last coating. No way in hell I want that in the car. What to do?
Old Feb 24, 2016 | 05:41 PM
Rick L's Avatar
You can try dusting it with Talc, or cornstarch. Now that it has set you could try washing it with soap and water.
Old Feb 24, 2016 | 06:11 PM
test point's Avatar
FlexSeal is probably nothing more than cheap undercoating at twice the price of what you can buy in any auto parts store.
Nati
Jan 16, 2016 05:10 PM
Iconoclast
Dec 22, 2015 02:10 AM
XJeej
Dec 20, 2015 10:15 AM
andyzeg
Dec 17, 2015 03:13 AM
auburn2
Dec 12, 2015 08:33 AM
