How to remove oil pan?
Dropping subframe is not worst case scenario, Crown Vics have welded crossmember and engine has to be removed to remove oil pan.
Yes, that's the best way. Support engine from above. Remove steering lower connector and lines, engine mounts, upper shock mount, xbrace, wheel speed sensors, calipers and I think that's everything ( I may have missed something). Then it's support it and unbolt it.
Even when you remove the lower sump plate (structural sump) there is still the upper plate that is the actual MAIN BEARING PLATE (bed plate). The plate and main bearing caps are all in one large part for strength and rigidity.
It will be in the way for most rotating components. The con-rod caps should be accessible through the bed plate slots but don't expect any room on the sides.
You will need to remove the front timing cover and gearbox. They both have bolts into the parts you need to remove (structural sump).
If you remove the primary timing chains and the bed plate, the crankshaft will fall out.
You might want to download my student guide V6/V8 engine repair course 168. I took my paper guide to a copy shop and had it converted to .pdf.
bob
bob
If "main bearing holder" of 4.2 looks like this one (Jag 3.0), I'll be fine,repairing connecting rod journals.f
I couldn't upload picture
https://www.ebay.com/itm/2005-JAGUAR...1R7:rk:11:pf:0
Jaguar uses a silicone based sealant (hylosil) applied as a 'bead' in areas shown in the Engine Repair Course literature.
bob
Yes,the oil pan is an easy removal. Just unbolt the pan and drop it off. This pan is just a cover plate, it does not have the sump in it.
There is a rubber gasket and that's it. The pan is small and simple. There is nothing in the way. Getting to the con rods is another matter since, as Brutal noted, there is a sub assembly frame between the pan and the main bearings. Not just a huge sump like an old American V8.
Per the workshop manual, the rod bearings and caps are installed with the crankshaft girdle in place.
Once you have the lower pan removed, you should be good.
https://workshop-manuals.com/jaguar/xjr_(x308)/v8-4.0l_sc_(aj27)/engine_cooling_and_exhaust/engine/cylinder_block_assembly/connecting_rod_bearing/component_information/specifications/page_1292/
https://workshop-manuals.com/jaguar/...ons/page_1292/
car5car
Feb 11, 2014 03:11 PM
BStopek
Mar 3, 2013 11:30 AM
