hydraulic hoses
hey forum, hows everybody out there............ well, back to looking for parts for when the weather breaks........... hydraulic hoses for 2001 xk8 conv. part # HJB8256AB from TOP HYDRAULICS in Florence Oregon at $ 134.99
what do ya think, price is awful low is it worth a shot to buy ????? Also looking for some decent rotas for the 2001 xk8............ any ides forum................tks Tony
I have same part number for the hose listed on recpt from a JAG DEALER that was put in my car from PO, it was list 393 sold for 314 bucks in May of 2014. Says 140B (could be an H, hard to read) Hose on description of it..
I had these hoses installed on my 2006 XK8 about a year ago. All is well so far. I think they are a very good product.
Jack
OK great................. did you get them from the same company " top hydraulics "
By me they want like a grand to supply and install the hoses.... maybe if I buy the hoses I should make out a lot better........ tks for the info..... Tony
in Oregon ?
I think a grand to buy the two hoses and install them is fair.
Jack
Consider doing the latch at the same time as the hoses. Maybe Top will give you a package deal...
We did my Rams and rear hoses last spring. Top Hydraulics will do what they are in business for and you won't be disappointed. Quick turn around if you sent off your latch or rams.
When you get in there your hoses will probably have the exterior falling off, so do the rears at this time saves paying someone to tear it all apart again. The fronts require a bunch more things removed, so as said, your price not bad.
Wayne
Wayne
its an all day job to replace the top lines but doable. have to remove the rear seat and drivers seat . and be flexible enough to get in under the dash . hardest part for me was fishing the lines behind the fuse box. I cut the old hose before the fuse box and taped it to the new hoses and pulled them thru, if you do it yourself place some cardboard to the trans tunnel next to the drivers seat and also the drivers door panel to keep the seat bracket from gouging the leather when removing .
I know , tough job but somebody's got to do it...... Don't think it will be me though LOL................ but gona wait till things warm up here and see.. thanks, Tony The Bronx n.y.
main thing is patience.... lots of plastic parts the will snap easily. but other than that its just lots of little parts to remove and replace. lots of tape to # parts and write down locations. most of it is pretty logical when you look at it .
FS[LowerAtlantic]: XK8 parts
batroute
May 23, 2016 07:18 PM
FS[SouthEast]: 98 xk8 parts or whole...
jaglenn
Jan 10, 2016 12:49 PM
