I couldn't wait put the italia's on today
Old Feb 16, 2012 | 04:10 PM
bigjohnsonjeeps's Avatar
Default I couldn't wait put the italia's on today
I took the afternoon off and put the wheels on today. They look good but I do need to lower the car around 1". How much does the H&R springs lower the car? Here are a few pictures. Now......... on to the front bumper.
Attached Thumbnails I couldn't wait put the italia's on today-xk8-rims-001.jpg   I couldn't wait put the italia's on today-xk8-rims-002.jpg   I couldn't wait put the italia's on today-xk8-rims-004.jpg   I couldn't wait put the italia's on today-xk8-rims-005.jpg
Old Feb 16, 2012 | 05:28 PM
Skid Mark's Avatar
Wow, you've got some serious tread on that car. Looks like the front is higher than the rear in the pic. Do you want to equalize the front and rear ride height when you lower it?
Old Feb 16, 2012 | 07:18 PM
No, the front isn't any higher. I think because the bumper cover is not on it looks like it is. Right now the tires are a 35 series. I think I will be going to a 40 series in the front. I also will be going to a bigger tire in the back. The fronts are a 275-35-18 now( rears are the same)and I will be going to a 275-40-18. And for the new back tires they will be 315-35-18. And yes they are going to fit. Alot of planing and measuring over and over to make sure it's right.
Old Feb 16, 2012 | 07:37 PM
The Coupe's Avatar
Tell us about the spacers...you've installed them front and rear, yes?
They look like 25mm or so, is that right? Where did you find them?
Lookin' good.
Old Feb 16, 2012 | 08:12 PM
I used a 1" spacer in front and for the rear I used a 1 1/2" spacer but also add a 5mm flat spacer in the rear. I ordered the spacers for a GM to GM. 5 on 4 3/4 to 5 on 4 3/4. They are hubcentric with a 70.5 center bore. I custom machined the mounting side and opened it up to 73.8mm and bored it to .500 (1/2) deep. Alot of work but it's now coming together.
Old Feb 16, 2012 | 08:23 PM
Skid Mark's Avatar
Will some of the tread come out from under the wheel well?
Old Feb 16, 2012 | 08:47 PM
Everything will be inside and under the car. I will have to roll the lip on the rear fenders, just to be on the save side after lower it.
Old Feb 16, 2012 | 11:26 PM
mjlaris's Avatar
Man, those are like Flintstones tires! You've got to post photos when you get it done. It'll be awesome!
Mark
Old Feb 16, 2012 | 11:40 PM
I ran this same set up on my 2000 LS1 Camaro. Most of the Dodge Vipers, Mustangs, Corvettes are also running this set up. The 315 is the MAX for the XK8. I also will have to do some rear wheel well mod's. I will show the pictures of that when I get to it.
Old Feb 17, 2012 | 10:11 AM
RCSign's Avatar
Big John
In the forth picture, I like the blade on the front. Getting ready for some serious plowing up there in Minnesota?
Old Feb 17, 2012 | 10:33 AM
I sure could use a ALL WHEEL DRIVE XK8 here in Minnesota during the winter. Maybe something in the future from Jaguar??????????
Old Feb 17, 2012 | 11:17 AM
Back when they created Jaguar-Land Rover as a division I was expecting to see something along those lines on a show stand as a crowd puller.
It would definitely have had your preferred scale of wheels and tyres as standard.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
AL NZ
Sep 4, 2015 08:39 PM
Sprayall
Sep 3, 2015 07:49 PM
