iCarsoft V2.0 - Can't clear some codes?
Old Nov 10, 2025 | 03:37 PM
LMG's Avatar
LMG
Default iCarsoft V2.0 - Can't clear some codes?
Decided to run diagnostics on my XKR before winter storage and the iCarsoft pulled 2 codes, neither of which it could clear:
Security module - U1135 - "Ignition state not obtained"
I think this one may be because I disabled the alarm backup battery as some have recommended?
Active damping (CATS) - C1516 - "5 Volts supply, circuit short to battery"
There are no issues with the CATS that I can tell, the ride is comfortable. Why would it throw this code?
I had the CTEK plugged in why running the diagnostics, shouldn't matter right?
Thoughts from anybody on what triggers the codes, and why iCarsoft can't clear them?
Thanks!
Old Nov 10, 2025 | 03:59 PM
User 42324's Avatar
You won't be able to clear codes where there is a constant active fault.
Old Nov 10, 2025 | 04:33 PM
LMG's Avatar
LMG
Ok, thanks.
I thought the typical troubleshooting procedure was to clear all codes and then wait a while to see what comes back.
Old Nov 10, 2025 | 04:50 PM
zray's Avatar
Originally Posted by LMG
Ok, thanks.
Some faults take a while to manifest “enough” to set off the code, others are the ON / OFF type and will throw a code immediately.
Z
Old Nov 11, 2025 | 04:18 AM
Orthodixie's Avatar
What model Icarsoft do you have? I am trying to select a unit for my ‘04 XK8. Keep having a periodic air bag light.
Old Nov 11, 2025 | 06:18 AM
User 42324's Avatar
Ok, thanks.
Some codes are reported without the engine running/car moving, as when ignition is on the car goes through self checks. If it's not clearing it indicates there's a fault, whether it can be felt or not.
Old Nov 11, 2025 | 07:14 AM
LMG's Avatar
LMG
I have V2.0.
The airbag light can be triggered by a fault with the SRS, you may want to check the connectors to the sensors in the a-pillars as a first, easy troubleshooting step.
Old Nov 11, 2025 | 08:07 AM
Orthodixie's Avatar
Thank you
Old Nov 12, 2025 | 02:54 AM
JaagXKR's Avatar
I have iCarsoft V2.0 too, and everytime I perform a scan with engine off, U1135 and U1141 error codes are always present, can be cleared only with engine on. The car has no issues at all, so I ignore them
Old Nov 12, 2025 | 03:08 AM
dibbit's Avatar
Good advice. This is like the engine temperature gauge being dumbed down to avoid owners getting worried that the needle is moving around. If the car is working ok, don't go looking for error codes and if you do find some unexplained codes, just ignore them. They are there to help diagnose problems, they are not problems in themselves.
Jrp79
Apr 22, 2017 10:35 AM
JagRag
Apr 24, 2015 07:59 AM
Lubino Do Rego
Jun 3, 2012 11:02 AM
brokenticker
Jan 14, 2012 02:14 PM
