Ignition coils
Old Dec 21, 2010 | 09:28 AM
Fla Steve's Avatar
Based on the pictures my 2000XKR has the AJ26 2 pin, but it's suppose to be an AJ27 engine?
Old Dec 21, 2010 | 11:04 AM
avos's Avatar
It’s kinda hard to tell if the one on the right in the picture is an AJ26 2 connector or AJ27 4 connector coil, as you can’t see the pins. Only way to check is to take of the ignition cover and count the wires going in the coils, it would be interesting to find a 2000MY (so vin Axxxxx) with a AJ26 engine.
Old Dec 22, 2010 | 08:50 PM
motorcarman's Avatar
The AJ26 connector is pictured here.
bob gauff
Old Dec 24, 2010 | 10:34 PM
2000blackxkr's Avatar
Default AJ27 coils
My coils are 4-wire on my 2000 xkr engine.
Old Nov 10, 2016 | 01:58 PM
wolfpck1's Avatar
my 99 xk8 conv has 4 pin coils.
Old Nov 10, 2016 | 04:37 PM
Gus's Avatar
Gus
The AJ26 uses the 2 pin the AJ27 uses the 4 pin.
Old Nov 11, 2016 | 08:39 AM
kreyszig's Avatar
I'm in the UK,have a 2000 4.0L, and it has 4 pin coils
Old Nov 11, 2016 | 09:02 AM
  #28
wolfpck1's Avatar
my code reader says I have a misfire on cylinder 3 replaced all plugs on passenger side and swapped the coils on 2 and 3 now code reads cylinder 2 so I figure bad coil. found one online from Walmart for 17 dollars and s/b here next fri will post after it arrives and have it installed as to the results.
Old Nov 12, 2016 | 05:30 PM
dennysjag's Avatar
If your on a budget there are many available through amazon or ebay. I replaced one bad coil with an aftermarket for about 35 bucks
Old Nov 15, 2016 | 07:21 AM
  #30
wolfpck1's Avatar
installed the coil from walmarts site yesterday looks the same as the jaguar coil and seems to be running fine 17 dollars sure beats 95.
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
millertic
Sep 30, 2015 08:11 PM
Bcrary3
Sep 27, 2015 12:21 PM
