Intake manifold
Old Jun 11, 2020 | 06:26 PM
Syb Drylst's Avatar
Default Intake manifold
I need to take off the intake manifold of my 97 xk8 to change the knock sensors, did anyone ever done this and is it difficult to do.
ill appreciate any comments on this topic
Syb
Old Jun 11, 2020 | 06:38 PM
NBCat's Avatar
Removing the inlet manifold is relatively straightforward, but bear in mind many of the plastic parts are going to be brittle and can easily break.
With the inlet manifold removed, also replace any coolant hoses that run under the manifold as they can leave you stranded.
Old Jun 11, 2020 | 07:22 PM
fmertz's Avatar
Some on this forum have claimed to be able to reach and replace these sensors without removing the intake manifold. Probably involves creative use of tools, or even sticky tape, but apparently doable.
Best of luck, keep us posted.
Old Jun 11, 2020 | 07:29 PM
Syb Drylst's Avatar
Thanks for the info, so I do have to take the trottle body of to?
Old Jun 11, 2020 | 07:35 PM
Syb Drylst's Avatar
Yes I heard them talking about it, I did tried to slide a tool in there a 24 mm crowth wrench but no way I can get in around the nut. I noticed that there are a couple different sensors mine has no upper nut on it to remove from the top, this one is one piece and has to come out in one piece, there must be a special tool for this.
Thanks for your info.
Cheers.
Old Jun 12, 2020 | 10:22 AM
NBCat's Avatar
Here is a link to the X100 Workshop Manual for vehicles fitted with the 4.0 litre engine:
https://www.dropbox.com/s/fok2shk4eg...al_4L.pdf?dl=0
Refer to section 303 for engine procedures.
Old Jun 12, 2020 | 11:15 AM
volkris's Avatar
A quick warning: I started to take mine off recently, but I found the electrical connectors to be completely frozen in place so I had to abort the process.
Maybe start with your electrical connectors so you find out up front whether that's going to be a huge complication.
Old Jun 12, 2020 | 04:41 PM
Syb Drylst's Avatar
Thanks so much for the workshop manual there's tons of great how to do.
Cheers.
Syb
yachtmanbuttson
Feb 5, 2020 07:37 AM
felinecat
Mark V - X 420G
Jul 14, 2017 11:35 PM
Gus
Jun 23, 2013 02:06 PM
The Coupe
Feb 27, 2012 10:43 AM
rianbechtold
Nov 28, 2008 08:51 AM
