Jtis
Old Jan 14, 2010 | 01:30 PM
hafferf's Avatar
Red face Jtis
HELP!!... I bought a new computer and now my JTIS doesn't work...and I can't remember where I downloaded it from... I could use a block of instruction please... I wanted to check for the lift points on my 98 XK8. I'm having new front tires installed on today, I wanted to make sure they put her on the "lift' correctly...;>(((
Drive on
Fast Freddie
Old Jan 14, 2010 | 02:49 PM
OregonJag's Avatar
Did you get one of the small notebook computers with the Intel Atom processor? I can't get my JTIS to work on my Asus Eee but it works on all other PCs I have access to.
Mike
Old Jan 14, 2010 | 06:42 PM
test point's Avatar
JTIS is indeed sensitive to the 'puter operating system. Worked fine on an older 'puter but took some fiddling to get it to work on Vista.
Old Jan 15, 2010 | 07:32 PM
Two jags's Avatar
Well maybe this picture will help.
Old Jan 15, 2010 | 07:42 PM
lakritstroll's Avatar
I got tired of trying to make JTIS work on laptop, desktop and at work (yeah, I know I shouldn't keep it there...) so I got VMware Player which is a free software which allows you to run virtual computers PC, loaded it with a WinXP machine and copied JTIS as an ISO image onto that virtual computer and now I have that package on a USB stick which I run on any computer that has VMware Player installed. Much easier than trying to make it work on Vista or Windows 7. Gives you the ability to run it on Mac or Linux as well...
Old Jan 15, 2010 | 10:33 PM
ABorealis's Avatar
Actually it is just as easy to run it on a Win7 PC. You install the add-on VM and WinXP mode options and voila, a virtual XP box.
Old Jan 16, 2010 | 12:50 PM
hafferf's Avatar
Wink Jtis
Thanks folks for all the replies.... They put her up carefully, and my new Michelin Pilots are onboard. However, I could still use the location of a good download site for the JTIS... perhaps that will replace the .dil file that "cannot be found"...
Fred
Old Jan 16, 2010 | 03:08 PM
Gus's Avatar
Gus
See if this will work on Windows 7 I (know it works on Windows Vista) – Go to your START and select it, you should have a menu and on it to the right is your HELP and SUPPORT button select it. You will see your help screen open, when it does enter in the search area “installing old software” and enter. Scroll down and you will see a section called Run the Program Compatibility Wizard. You will also see other options that may help; however, I would recommend that you not use the manual settings unless you know what you are doing. Good Luck! Just an FYI you may want to be connected to the net. You may need to get a driver or two (not for your car).
Old Jan 16, 2010 | 04:38 PM
test point's Avatar
I see you found the download site on the 'General Jaguar Site'. Did it work for you?
Old Jan 17, 2010 | 11:49 AM
hafferf's Avatar
Unhappy Jtis
Gus, that did't work. When the program (JTIS) loads, it says "file SV21WR32.DLL not found" I need to find the site and download. And Testpoint... No...it didn't work. There was a fellow here (Christo I think) that was providing a site, but I can't seem to reach him. Does anyone out there know of a download site!!...;>(((
Old Jan 17, 2010 | 12:50 PM
Gus's Avatar
Gus
Go to the manufactures’ page for your computer, select help and copy and paste your error and see what they have to say. If you call chances are you will get tech that has no idea what you are talking about and you will be on the phone for hours.
Did you download or get a disk? You could have a problem with either one. In most cases the software has what it needed to install and run the program.
Try this
http://www.cannell.co.uk/Jaguar_Work...uals/JCD-1.zip
http://redirectingat.com/?id=42X198&...uals/JCD-1.zip
JTIS DIRECTORY
http://software.informer.com/getfree-find-jtis-program/
http://www.filestube.com/j/jtis+download
Let us know the one that worked!
Old Jan 17, 2010 | 07:19 PM
hafferf's Avatar
Try this
JTIS DIRECTORY
Thank you Gus for the help. I finally got it downloaded...however...it doesn't seem to be compatible to "Windows 7" , so now I have to wait for the windows folks to get back to me on how I can make her run...;>(((
Thanks again.....
Old Jul 10, 2011 | 08:31 PM
ka1thm's Avatar
Default Loading OS and program questions
Hello Sir,
I loaded the player and am at the point where it asks me to load a guest operating system. Could you please give me the steps from what OS you loaded via a CD or ISO, and how you loaded the program onto the guest OS?
Thank you
<<<Mathew>>>
Old Jul 10, 2011 | 08:45 PM
Fedoraja1's Avatar
A little searching goes a long way. XK8 & XKR Frequently Asked Questions / DIY Repair & Maintenance Links / Facts & Data
Should that not work, try this link. Installing JTIS on Windows 7 (32 bit and 64 bit)
Good luck.
Old Jul 10, 2011 | 09:19 PM
Fjk's Avatar
Fjk
Follow the instructions At the "Note:"
JAGUAR MANUAL (JTIS) INSTALLATION INSTRUCTIONS:
1. Insert CD in drive, open CD, run “Setup.exe” program.
2. Once JTIS program is installed, remove JTIS CD. Restart Computer. After computer is fully restarted, re-insert JTIS CD. Navigate to JTIS program through “Start” menu to “Programs”. Start JTIS program.
3. Proceed to the “Help” icon for complete operational instructions.
4. Once JTIS program is started, select “Service”, select model & model year, then use “Text Navigator” button on bottom of screen (2nd from right).
Note: The first time you install JTIS on a PC, it may be necessary to install Data Access Objects 3.5. If you are unable to access service directories, DAO 3.5 must be installed. Install DAO 3.5 by opening DAO35 folder on the JTIS CD-ROM. Then open “Disk 1” folder, and run the SETUP.EXE program from this folder.
IMPORTANT: THE JAGUAR SERVICE MANUAL “HELP” FEATURE INCLUDES COMPLETE OPERATIONAL INSTRUCTIONS AND MUST BE UTILIZED TO GAIN FULL BENEFIT FROM THIS CD!
Old Jul 12, 2011 | 05:47 PM
SeismicGuy's Avatar
I think that if you install off the CD then you always need to insert the CD when running. I copied all of the stuff off of the CD and onto a directory in my hard drive and installed from there. I do NOT need to insert the CD when running the JTIS.
Doug
RaceDiagnostics
Jul 7, 2022 06:41 AM
duecedriver
Dec 25, 2015 11:47 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
Bcrary3
Sep 19, 2015 02:47 PM
