Just bought a 2000 XK8 - question about options
Old Apr 7, 2010 | 08:25 PM
kdross's Avatar
Default Just bought a 2000 XK8 - question about options
I just purchased a 2000 XK8 convertible with 43K miles (02/2000 production date). I plan to change the hoses for the pump for the convertible top since that seems to be a common problem. Plus I will flush the tranny fluid and install a new filter.
One question I have is how can I determine what options this car has? It does not have the GPS system, but how can I determine if the car has other options (premium radio, etc). I have yet to find any information as to what options were available.
Thanks.
Old Apr 7, 2010 | 09:22 PM
H20boy's Avatar
I think the Nav and the premium sounds system were the only options on these cars.
Adaptive cruise wasn't available for a few more years. Everything else was standard as far as I can remember.
If you've got 6 speakers up front, two 'subs' in the rear, and a separate amp atop the CD changer, you've got the premium setup.
Old Apr 7, 2010 | 10:20 PM
K.Westra's Avatar
I was starting to type it out, but then I renumbered that Jaglovers has a few brochures scanned.
Here is the options page from 2000:
Granted it isn't perfect (ex: you can't get CATS with a convertible and I think Matt is correct that adaptive cruise didn't come until later) but it is a start.
Old Apr 7, 2010 | 10:30 PM
kdross's Avatar
Thanks for the replies. There is no amp above my cd player in the trunk, so I guess I have the standard radio. The premium radio would have been nice to have.
Old Apr 8, 2010 | 11:18 AM
H20boy's Avatar
several xk8/r owners have added the speakers, only too an aftermarket amp to do so.
K.Westra, next time, try a screen capture, the link is always protected like that above... shows standard jag-lovers shot.
Old Apr 14, 2010 | 09:47 AM
walt_00XKRConv's Avatar
Default Hydraulic hoses
Re: your comment about changing the hydraulic hoses. My suggestion is that you lift the latch cover and examine the condition of the hoses at the fitting where they join the latch cylinder. This only requires the removal of a few screws. Be careful with the rubber seals at each end as some screws are located beneath.
If the hoses are OK (it will be obvious) then think about installing the pressure relief kit. This reduces the pressure by about 1/3 and will not only preserve the hoses but will also prolong the life of the lift cylinders. The rod seals on the lift cylinders fail almost as often as the latch hose.
If the hose is degraded then your first priority should be there. You are talking about $500 for the parts to do both the hoses and the kit. My car has factory replacement hoses that were replaced prior to my purchasing the car. They are still OK and I see no reason to replace them now that I have the pressure relief kit. With 43K I would be surprised if the hoses haven't been replaced. Most cars don't make it to 50K unless they never got hot and the roof was seldom used. Warm climate cars are lucky to make 30K.
Old Apr 14, 2010 | 02:04 PM
ajmac's Avatar
My 97 has the Premium sound option - it really is a quality setup.
Wouldn't CATS have been an option too? I miss that on mine, as far as I know it has all the early options as it was originally a dealer 'show' car in London so it was fully optioned to impress on the test drives etc...
Old Apr 16, 2010 | 08:16 AM
K.Westra's Avatar
Good to know. I checked this post from work and it appears like you say. From home I get the proper image. Here is what I was posting:
Old Apr 16, 2010 | 12:59 PM
H20boy's Avatar
kd ross, got your email. Man, w/o looking at your vehicle, not sure if you have it or not. Anyway you can check your VIN with a dealer, see if it was on the list of options?
kelliott
May 31, 2022 05:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
XFR_Gold
Sep 2, 2015 12:24 PM
