Keyfob reconnect won't work
After replacing the battery of my key fob I tried to reconnect it following the steps as found on Youtube etc. However when I pushed the buttons on the keyfob a beeping sound came from the back of the car (alarm?) and the key fob refused to connect. The red light on the J gate didn't come on either. Did I do something wrong? The second key fob still works fine.
There is no need to reconnect the FOB when replacing the battery, it should work OK straight away.
Because your second FOB works OK it sounds as if there may be more at fault with it than just a flat battery.
Z
PS / is there a chance you put the battery In backwards ? (No offense intended, it happens)
