Keyfob reconnect won't work
Old Apr 1, 2026 | 10:08 AM
Bart Jacobs's Avatar
Default Keyfob reconnect won't work
After replacing the battery of my key fob I tried to reconnect it following the steps as found on Youtube etc. However when I pushed the buttons on the keyfob a beeping sound came from the back of the car (alarm?) and the key fob refused to connect. The red light on the J gate didn't come on either. Did I do something wrong? The second key fob still works fine.
Old Apr 1, 2026 | 12:33 PM
Stumpy's Avatar
There is no need to reconnect the FOB when replacing the battery, it should work OK straight away.
Because your second FOB works OK it sounds as if there may be more at fault with it than just a flat battery.
Old Apr 1, 2026 | 12:45 PM
I had to replace the battery and wanted to reconnect it, at least that's what I understood from 2thegarage etc. But I'll ask my local specialist to sort it out. Thanks!
Old Apr 1, 2026 | 07:31 PM
zray's Avatar
@Stumpy is 100% correct. No need to re configure the fob when doing a battery replacement. One action does not affect the other.
Z
PS / is there a chance you put the battery In backwards ? (No offense intended, it happens)
Old Apr 2, 2026 | 03:33 AM
dibbit's Avatar
You don't say what year your car is, but earlier cars used two batteries not one - so if you did in fact change "the battery" and not "the batteries" it won't work.
Photo by Motorcarman.
Jonty Angle
Mar 9, 2022 03:37 PM
Spider589
Oct 30, 2020 03:14 AM
goodgame
Nov 21, 2017 01:46 PM
craigbfg
Oct 30, 2013 09:33 AM
quaker13
Mar 4, 2012 08:08 PM
