keys in trunk, battery disconnected 2001 xk8 convert
Old Oct 19, 2014 | 03:30 PM
cobrawet2's Avatar
Default keys in trunk, battery disconnected 2001 xk8 convert
OK.....looks like a perfect storm here
I disconnected my battery and then proceeded to lock my keys in the trunk.
Any ideas?
Any good way to cut and get inside????
This is a bummer
Does anyone know where the trunk latch actuater is located?
I am thinking if I can get access to the solenoid all I would have to do is power it or pull the cable or something.
Assuming I will have to cut into the bodywork somewhere.......
Old Oct 19, 2014 | 03:36 PM
Loxmth's Avatar
Well that sucks to say the least. As a locksmith I would say call a locksmith. You may be able to power the car up from under the hood passenger side under the cover near the windshield. I've jump started my car that way.
Old Oct 19, 2014 | 03:48 PM
DaveInVA's Avatar
You can also power it up from the cable from the alternator as that cable ultimately goes to the battery B+.
Someone posted they were able to get the trunk open through the gas filler grommet but with no power it may be hard to get that open also.
Otherwise it may be time for one of these:
Dave
Old Oct 19, 2014 | 04:37 PM
Paul Pavlik's Avatar
If the car doors are unlocked, release the Hood (Bonnet) and connect a jumper cable as shown and use the Trunk Open button on the Dash.
Old Oct 19, 2014 | 04:48 PM
cobrawet2's Avatar
car is unlocked.
if I power up the car as shown will the trunk release function work or do I nee the key fob/key?
Hood is open already
Old Oct 19, 2014 | 05:04 PM
Originally Posted by cobrawet2
car is unlocked.
Trunk will release without Key (unless it was in Valet Mode).
Don't attempt to start Engine until Battery is re-connected.
Old Oct 19, 2014 | 07:41 PM
cobrawet2's Avatar
OK.....could not use the under the hood connections as the disconnected battery cable was grounded laying against metal.......big spark when trying to connect.
I cut a hole in the lower passenger side trunk area and was able to get my hand on top of the battery and connect the positive lead.
Yea!!!!! trunk opened......but the computer seems to be wacky and now the car wont start. When I hit the door open button the locks cycle a few times......so something is goofy.
I am going to fully charge/check the battery so as to take care of the obvious stuff as I have heard a battery can mess with the computer.
Will try it again tomorrow, but this was sure better than cutting a hole in the trunk!
Hope I did not fry the computer.....sigh
Thanks everyone for your help!!!!!!!
Charlie
Old Oct 19, 2014 | 07:46 PM
Jandreu's Avatar
Good for you and good luck with the control modules as you have now shorted the system when you tried to jump it from under the hood. I hope you get lucky with this.
I think I would have called a locksmith but hind site is always 20/20.
Old Oct 19, 2014 | 08:08 PM
cobrawet2's Avatar
am hoping that the power just went to ground as the key was not in it........we will see!
Old Oct 19, 2014 | 08:37 PM
Jandreu's Avatar
I accidentally back feed 12v positive into my can bus and the car acted weird for about a day but straighten out with no other issues.
Old Oct 20, 2014 | 11:23 AM
cobrawet2's Avatar
well....hoping for the same result!
If not......will go down the check list here on the forum......starting fluid, check furl pres at fuel rail.....make sure all relays are seated.......scan codes.....yuck
Old Oct 25, 2014 | 08:30 PM
5V1900's Avatar
[QUOTE=cobrawet2;1082157]OK.....looks like a perfect storm here
When I read this, I thought "how could anyone be so dumb!" and then the very next day locked my keys in the trunk after showing a friend how clean my trunk was. Fortunately I was lucky as well as dumb, as the top was down so I just pushed the button. I was 300 KM from home and the spare keys, by the way.
Old Oct 27, 2014 | 10:20 AM
cobrawet2's Avatar
LOL.....well....I cut my way in.....connected the battery and repaired all tha damage so it looks better than new!!!!!!!
All is good.....just have to clear a check engine light.
Old Oct 27, 2014 | 05:00 PM
astromorg's Avatar
This might be a suitable time to resurrect this as a stopgap until WhiteXKR gets his version in production!
https://www.jaguarforums.com/forum/x...cy+boot+access
Old Oct 31, 2014 | 11:29 AM
cobrawet2's Avatar
That is a pretty clever idea.....makes sense.
I wonder if you can "wire in" to the trunk latch solenoid and have a couple of hidden termanals and hit it with 12v outside the car?
Anybody know where the solenoid is?
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
philwarner
Oct 4, 2024 01:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
