Left tail light and rear side markers and trunk lites
Old Apr 26, 2020 | 03:25 PM
HalBrown's Avatar
Default Left tail light and rear side markers and trunk lites
The left tail light and the rear side lights and trunk lights do not work in this 2000 XKR I just purchased. The backup, fog, and signal lites do work on that side. I have ordered new ford sockets for the side marker lights but it does not seem like they are getting power. any help would be greatly appreciated. thanks Hal
Old Apr 26, 2020 | 03:52 PM
Cee Jay's Avatar
Oops, you're in the wrong forum. This is the X150 forum for the 2007-2015 alloy bodied XX and XKR.
You need the X100 forum for the 1997-2006 models.
Old Apr 27, 2020 | 12:58 PM
Welcome to the forums Hal,
I've moved your question from X150 to X100 forum. Members here with the same model will be able to help.
Old Apr 28, 2020 | 01:27 PM
michaelh's Avatar
Hal,
Here's the relevant section of the 2000 electrical guide:
Fuse F21 (5A) in the trunk fusebox would be my first move since it feeds the LHS tail lamp and the rear side markers (RW red/white wire). I take it you're not seeing any 'bulb fail rear' or similar messages?
The missing trunk lights could be either the switch, or fractured wiring in the loom by the RHS lid hinge.
Old May 8, 2020 | 07:38 AM
HalBrown's Avatar
Originally Posted by michaelh
Hal,
I will see if that is the problem, but now while checking the light, I ran the battery down and now the check engine light is on. Says knock sensor code. Do I need a new Knock sensor?
Old May 8, 2020 | 07:41 AM
HalBrown's Avatar
I have a beautiful yellow Spitfire, but its wiring is nothing like this Jag, lol
Old May 9, 2020 | 02:31 PM
michaelh's Avatar
Give the battery a good charge, then check the voltage after an hour or so of resting. If it's lower than around 12.5-12.6V then it may be due for replacement.
Clear the code and see if it returns.
My MGB has a total of 5 fuses, including the in-line for the stereo.
Old May 9, 2020 | 03:05 PM
HalBrown's Avatar
yes, the LHS tail light is out even though the back up and signal works. the fuse layout is not on the to of my fuse box so I have to try and find the correct one. Would this also cause the check engine light to come on with a code of PO 328? Something to do with the knock sensor it says.
Old May 9, 2020 | 04:12 PM
HalBrown's Avatar
OK, you have solved that problem. it was the fuse.I just checked all the 5 amps. one was bad. Now to order a new master window switch and new radio. Yeah. Thanks a bunch, Hal
Old May 10, 2020 | 12:41 PM
michaelh's Avatar
Highly unlikely, but a failing battery can cause spurious codes to be thrown. Try the simple checks first:- getting at the knock sensors on the R is not a trivial job.
DTC summary for P0328:
Good luck!
Stillill
Jun 7, 2018 07:43 PM
scardini1
Feb 29, 2016 03:48 PM
rellsimone
May 16, 2014 07:25 PM
dmsdvls3
Jun 17, 2010 09:20 AM
Jan 22, 2007 12:38 AM
