Lights on auto, battery dies overnight
Old May 26, 2014 | 10:59 AM
mrobinson's Avatar
Default Lights on auto, battery dies overnight
Hi,
I've noticed recently that when I leave my lights on auto, the battery drains overnight. If I switch them off, it doesn't drain.
Can anybody think of anything obvious that could cause this? The lights themselves do turn off once the engine is off ( on auto ).
It's a 1998 XK8 Coupe, UK.
Old May 26, 2014 | 12:02 PM
scm's Avatar
scm
Do you lock the vehicle?
Old May 26, 2014 | 01:10 PM
mrobinson's Avatar
I almost always do - I'm pretty sure it was locked earlier.
I should add, I had Halfords check the battery a couple of weeks ago and they said it was as good as new. I'm pretty sure the alternator is ok too - it shows as 13v on the dash sensor, and the battery got to half full on the drive to Halfords after a jump start ( from empty enough that the lights wouldn't come on ).
Old May 26, 2014 | 01:17 PM
mrobinson's Avatar
I've been informed by SWMBO that the car was definitely locked earlier ( the last time I used the car before I found it was flat was Saturday ).
Old May 26, 2014 | 01:18 PM
WhiteXKR's Avatar
Your statement above provides the clue.
The electronics will often not reset properly after a jump start to a dead battery. Disconnect the battery for 30 seconds then reconnect it to reset everything.
You also would be well advise to charge the battery. A 'half full' battery on this car is inviting electronic problems. Also the dash meter is highly inaccurate, and with a weak battery the voltage can drop very low during starting, corrupting the operation of the electronics.
Old May 26, 2014 | 03:46 PM
mrobinson's Avatar
Thanks, I'll give that a try, although 'half full' was what was measured by the battery tester at Halfords ( ~400 of around 900~, although I don't know what units ). I then drove the same trip home, so I'd imagine that the battery should have been roughly full by the time I got home.
Is there any way once I've reset the electronics that I can test the battery isn't being drained other than by seeing if my battery is dead the next day?
Old May 26, 2014 | 05:46 PM
JagV8's Avatar
Ideas:
1. battery no longer holds charge no matter how you charge it - common and causes problems
2. some other fault - on an S-Type the sorts of places to look are the flap where the key goes in the ignition and the stalk for auto lights (whose wiring chafes)
Old May 26, 2014 | 09:34 PM
motorcarman's Avatar
Some of these may or may not apply but here for reference.
bob gauff
Old May 28, 2014 | 11:56 AM
azeteg's Avatar
Appears this has been happening to my car all along. I have just resorted to always using a trickle charger at home.
I notice that there is some quiescent current by looking at my DRL's. I replaced them for LED bulbs, and they keep being lit a tiny bit at all times.
I just tried setting the stalk to Auto yesterday, and after a couple of minutes the LEDs now go out.
So, appears that I should install this link lead. It just appears to be a diode? Would it be ok to just splice a 1N4007 or something in there? (In what direction?) Looks easier than struggling with finding this overpriced cable.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
