Lincoln LS Parts Interchange
Old Apr 10, 2011 | 09:19 PM
Spurlee's Avatar
Default Lincoln LS Parts Interchange
I understand that some/many Lincoln LS engine parts interchange with the XK8.
I have a MY2000 XK8. Is there anything more to know than just asking the parts counter guy to reference a MY2000 Lincoln LS with a 4.0L and comparing the parts?
Old Apr 11, 2011 | 07:24 AM
K.Westra's Avatar
Well the Lincoln LS engine is a 3.9 I know the tensioners are the same, but the block, crank, rods, and pistons are different. That is the extent of my knowledge.
Old Apr 11, 2011 | 07:03 PM
Beav's Avatar
I think we should have a sticky listing parts found to be interchangeable with the LS. It could potentially save each of us some money.
Old Apr 11, 2011 | 07:41 PM
07XKJaguar's Avatar
Found out by chance that the thermostat is the same. Went to the Ford dealer since I was in a bind having to order one, and he even showed it crossing over. Was on a 97 XK8.
Old Apr 11, 2011 | 08:48 PM
plums's Avatar
Cheaper from Ford?
Old Apr 11, 2011 | 09:28 PM
test point's Avatar
Cheaper than Ford?
Gotta be!
Old Aug 15, 2016 | 08:52 AM
K.L. Champ's Avatar
Default Lincoln ls
I have a question if anybody know if the s type jaguar dccv is compatible with lincoln ls? interchangeable part number XR822975
Old Aug 15, 2016 | 09:10 PM
auburn2's Avatar
I don't think the block is any different.
Old Aug 16, 2016 | 01:03 AM
JagV8's Avatar
Try Motorcraft YG-355
Old Jun 9, 2019 | 09:59 PM
Paula Vecchiarelli's Avatar
Anyone know if the MAF sensor is interchangeable with the Lincoln LS?
Old Jul 1, 2019 | 09:04 AM
Default A/C control relay
Just wanted to let everyone know, the relay for the 2003 Jaguar S-Type 3.0 is the same for the 2003 Lincoln LS. O had to replace this and the auto store did not carry the Jaguar part so I told them to look up the relay under the LS. Perfect match!
Old Aug 29, 2019 | 03:04 AM
Mike Lore's Avatar
97 Xk8 uses the same valve cover gaskets,they were less than half of Jaguar OEM.
Scott B
Oct 24, 2015 01:29 PM
convincor
Sep 10, 2015 06:50 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
