Locking lug nuts
Old Aug 16, 2010 | 10:11 AM
Max's Avatar
Max
Default Locking lug nuts
Has anyone found a good set of locking lug nuts for use with OEM wheels?
Thanks...........
Old Aug 16, 2010 | 11:23 AM
vagearhead's Avatar
The only ones I was able to find were the OEM Jaguar ones. I ordered mine from www.jagbits.com
I think I paid about $125 for the set of 4 with two keys.
Old Aug 16, 2010 | 10:05 PM
Max's Avatar
Max
I talked with Jagbits and they described the locking lug nuts as their site didn't have a graphic. The attached is what I believe they were describing. Is that what yours looked like?
Old Aug 17, 2010 | 08:35 AM
vagearhead's Avatar
Those are close. The locking design and the key are the same but the shank is a smaller diameter for the XK and they have washers which go over them.
Old Aug 17, 2010 | 08:51 PM
Max's Avatar
Max
Thanks for the update.
I am investigating a set our local dealer has and will start another thread with pictures if they are promising.
Old Aug 18, 2010 | 12:56 AM
MrTexasDan's Avatar
If they are the type that the $15 Locking Lug Nut Removal Socket available at most auto parts stores will remove, then I wouldn't exactly call these good. You can bet that all wheel thieves have these removal sockets.
Old Aug 18, 2010 | 08:25 AM
Max's Avatar
Max
Agreed.
I would hope the locks sold by Jaguar would be better than the run-of-the-mill stuff.
We shall see.
Old Aug 18, 2010 | 11:42 AM
vagearhead's Avatar
I can tell you for sure security wise, the ones I got (the genuine Jaguar ones) are no better than the run of the mill wheel locks you'd get through any auto parts supplier.
While the fit and finish is nice on them there's nothing that would stop a somebody who knows what they are doing from hammering a socket over them to remove the wheel. When I put the BBS Detroits on the car I figured these would be better than nothing.
I've used these on past cars and they are the best I've seen but I couldn't find a set I know would fit the XK.
http://www.gorilla-auto.com/gorilla.locks
If anyone finds another option with a better design please let us know.
Old Aug 18, 2010 | 01:00 PM
oldmots's Avatar
The Jag locks for the Detroits looks just like the regular long bolt, except it has a removeable stainless cover that hides a round shaft with two grooves in it and comes with a socket that fits over these two grooves. Should work okay to stop a casual thief. One with tools and skill could probably bypass them. They are better than nothing.
Old Aug 18, 2010 | 02:51 PM
Max's Avatar
Max
The locks I received today are the same as described above. For the few nights a year the car isn't garaged they are reasonable protection against theft, and better than the run-of-the-mill stuff.
Johnken
Apr 8, 2018 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
MrWhite
33
Oct 22, 2015 10:29 AM
millertic
Sep 30, 2015 08:11 PM
