loos exhaust , xkr 2001
Old Oct 7, 2010 | 09:30 AM
tanngo's Avatar
Default loos exhaust , xkr 2001
loss of exhaust manifold area, only cold morning, suggestions, sorry lenguage
Old Oct 7, 2010 | 09:40 AM
tanngo's Avatar
xkr 2001 , 17.000 milles ,
morning to start the car, listening to a loss in the exhaust manifold gasket. is eliminated by driving time is normal, the engine is something ....
Old Oct 7, 2010 | 10:02 AM
tanngo's Avatar
sound can be heard below the throttle body, and feels a little smell of burning gas, my question is whether it is normal ..
sorry for the post, I try to understand
Old Oct 7, 2010 | 10:40 AM
H20boy's Avatar
tanngo, are you saying that you are hearing a 'blowing' type of noise rear of the throttle body, maybe under it? A slight air noise is normal on mine, maybe even more pronounced on an XKR with the SC, I am not sure.
Now, a smell of exhaust, that is a different matter altogether. I've not heard of any exhaust manifold leaks with that range of 4.0L engines. If you're sitting still, engine running, you may be smelling the exhaust that is surrounding the car, it will be heavier than air until it becomes dispersed in time.
If the exhaust is leaking at the manifold, I am pretty sure the 02 sensor data would trigger some kind of fault, a check engine light, and perhaps the engine would not run smooth.
I am not totally confident in my statement, so If anyone else can chime in, that'd be great.
Old Oct 7, 2010 | 11:34 AM
tanngo's Avatar
HELLO, THANK YOU. LISTEN IN THE CAR IN COLD ,NOISE SEEMS VALVES.... BUTTERFLY BODY ZONE COMES, exhaust manifold.
HOT GO AWAY, NO WARNING LIGHT.
Old Oct 7, 2010 | 12:25 PM
tanngo's Avatar
Because I started my research, Began to hear a noise like valves, Which Are deleted after 10 minutes of driving.
A LOW SPEED IS NOT LISTENING.
Old Oct 8, 2010 | 10:15 AM
H20boy's Avatar
noise-like rattling at cold startup could be indication of timing chain tensioner problem. I'd inspect them if you haven't already done so, just for peace of mind. Or it could just be circulating oil before the valves are fully lubricated?
Old Oct 8, 2010 | 12:09 PM
tanngo's Avatar
zone is exhaust manifold, throttle body, I think it exhaust gasket ....
Old Oct 8, 2010 | 12:15 PM
tanngo's Avatar
hose in my ears, walking area and feel leaking exhaust pipe exiting exhaust manifold throttle body area
Old Oct 8, 2010 | 01:11 PM
H20boy's Avatar
well, if you can feel the exhaust gases, that's not good.
Old Oct 8, 2010 | 03:58 PM
tanngo's Avatar
thanks h20boy. There is a pipe coming out of the exhaust manifold, where it is headed and what it does ... I think the loss
my jaguar xkr only 17.OOO MILLES .
Old Oct 8, 2010 | 07:47 PM
tanngo's Avatar
I found ... This cracked the EGR valve pipe from exhaust manifold.
someone can help me remove the pipe ....please
Old Oct 9, 2010 | 07:29 PM
H20boy's Avatar
That should be an easy replacement, but unfortunately, I haven't had to do mine or seen how to take one out. Do you have the jaguar technician information system CD? if not, it might have the procedure step-by-step.
Old Oct 9, 2010 | 07:32 PM
Jaxkr's Avatar
It sounds like the EGR pipe is leaking.
Old Oct 11, 2010 | 07:41 PM
tanngo's Avatar
Hi, I have the egr tube cracked, I will proceed to repair
Old Oct 11, 2010 | 10:03 PM
WhiteXKR's Avatar
Default There is a TSB for this repair
Tanngo-
The original 2000-2002 XKR EGR tubes often cracked. Now there is an updated part. There is a factory TSB for this procedure. I have attached it. I hope it helps you. I have only the pages that apply to the XKR, so it may look like there are some pages missing.
File Type: pdf
Old Oct 12, 2010 | 12:10 PM
tanngo's Avatar
perfecto , thanks , gracias , ....exelente .
Old Oct 12, 2010 | 12:11 PM
tanngo's Avatar
was what I needed excellent -....
Old Oct 12, 2010 | 12:43 PM
WhiteXKR's Avatar
que son muy bienvenidos
toronadomike
Jan 22, 2026 10:13 PM
picard
Oct 12, 2015 11:56 AM
JeffG94
Sep 14, 2015 07:33 PM
LondonXK8Boy
Sep 14, 2015 08:26 AM
skadmiri1
Sep 9, 2015 11:27 AM
