Low Coolant message
Old Feb 5, 2011 | 08:24 PM
64Driver's Avatar
Default Low Coolant message
As I drive around (99XK8) every so often I get the low coolant message. I've checked the coolant reservoir, it's full and the temperature guage is normal and the engine does not seem to be heating up. Any ideas what it could be?
64Driver
99 XK8
04 XJ8VP
Old Feb 5, 2011 | 09:03 PM
Gus's Avatar
Gus
I have been down this road this link might help http://www.gusglikas.com/AutoRepairCoolantTank.htm
Old Feb 5, 2011 | 09:11 PM
brgjag's Avatar
I had this once. Car was always fine but one day I was HAMMERING IT on the hwy and the light came on. I guess the high speed has sucked down more fluid? I topped it off, 2 years later no issues.
Old Feb 5, 2011 | 10:09 PM
64Driver's Avatar
Gus, thanks for the link>
I'll pull the tank apart tomorrow and clean it up.
64Driver.
Old Feb 6, 2011 | 05:29 AM
XKRacer's Avatar
Another possibility can be a faulty cap, this allows too much water to got to your atmosperic tank in your right fender.
Old Feb 6, 2011 | 07:07 AM
Gus's Avatar
Gus
64Driver.
Be careful the tank and few of the hoses are often brittle. And AKRacer has a good point to check the cap.
Old Feb 6, 2011 | 09:03 AM
avt007's Avatar
It's a good idea to fix this problem. I had an RX7 with the same problem. It got so that I ignored the light because it came on once every week or two.
One day it comes on, I ignore it, then glance in my mirror on the freeway, only to see a cloud of steam following me! I had blown a heater hose. Luckily I noticed it before any damage was done.
Old Feb 6, 2011 | 09:16 AM
Dennis07's Avatar
Another suspect: the float. I've seen it reported that it can take on a little coolant and so start riding lower than it should.
BTW, the gauge is pretty useless. It won't show you much until things are way too hot.
Good luck.
Old Feb 7, 2011 | 04:39 PM
jnporcello's Avatar
I've also seen that they are a very temperamental sensor. It sometimes only takes it to be down a few ounces to set of the light. At that age, there's a good chance you're leaking from somewhere, but it doesn't take much to set off the alarm.
Wahooesprit
Dec 23, 2019 02:01 PM
jimmiejag
Sep 9, 2015 02:56 PM
1100me
Sep 7, 2015 06:26 AM
Xkr x100
Sep 6, 2015 08:50 AM
XFR_Gold
Sep 2, 2015 12:24 PM
