Low Oil Pressure 1997 XK8
Was about to pull out from a parking lot, engine cuts out, "low oil pressure" light came on. Had it towed to my mechanic, he will be looking at it today. Fingers crossed the engine is OK. Assuming this is an oil pump, any sources for the replacement other than eBay?
Thank you.
Thank you.
Yep, that is exactly how it happen. Engine stopped and then the light came on. I am waiting to hear from the mechanic, expecting it to be an oil pump. Found some options on eBay, will reach out to you guys to make sure I am ordering the right part once I hear back. Incidentally, how hard is it to replace the pump, is it more or less easily accessible?
Thx
Thx
I do have what should be a pretty low mileage 97 motor that I got from a parts XK after I got a little too close to a deer. The car had 130k on the odo but it is a jaguar remanned so I would assume it would have a good deal less mileage. If the mechanic finds the worst you might be able to pry it out of my hands. Never heard it run but the car was dead from a bad tranny when I got it so would suspect it is just fine but I would do tensioners before installing it. LOL
Thx
Thx
I hope your mechanic can determine why the engine quit, that's more to the point.
Just talked to my mechanic. He is scratching his head. Said the car is full of oil, oil is clean, he doesn't think it is an oil pump, but he can't get the car running. He is also having hard time hooking up his computer. I told him that I turned AC on 15 sec before it happened, he said that the AC is currently off. Any ideas?
Stop trying to make it more complicated, although it is a Jag. If your mechanic can't check for fuel pressure at the rail and spark you need a new mechanic.
Also since it's a nikasil lined engine, any attempts to start it cold without success could result in bore wash if the fuel pump is working. Other engines can also have the same issue, but the early Jags are particularly susceptible.
Please keep us informed.
More information would be helpful .................
Does car lock and unlock OK ?
Do all lights on dashboard come on when key is turned to position 1.
Does engine turn over (crank) when key moved to position 2.
With ignition on, and foot on brake, can you move the gearshift lever.
What sort of "computer" is your mechanic using ?
How old is the battery and what is the voltage ?
Is there any fuel pressure at the Schrader valve (like a tyre valve) at the front of the engine on the right-hand (looking from front) side ?
Yes
Yes
Yes
Yes
Not sure, Sunoco station, I could find out.
Replaced last month.
Will find out and report back.
Thank you for your help
Yes
Yes
Yes
Yes
It's at a "gas station" Get it out of there! You need a specialist to check crank and cam sensors assuming it has normal fuel pressure. Find an Indie British car shop. Check reviews of any shop before committing the car.
I have been using them for a very long time. If can't figure it out he will tell me but so far he has been handling all my cars for the past 15 years including some pretty involved stuff. He checked the gas pressure, saying it is over 40 pounds holding pressure whatever that means.
Okay, you probably have bore wash now on top of any previous problem. Have the mechanic check compression, it will probably be very low.
Do a search of bore wash on the forum if the compression is low and show the results to the mechanic. A small amount of oil in the cylinders is the cure.
Left a message for Marotas this morning, haven't heard back yet. I am ok with the ex jag guy if he is up to the challenge, if you don't mind please pm me his info. Thanks for your help.
