Low Oil Pressure 1997 XK8
Old Jul 31, 2017 | 07:39 AM
reko19's Avatar
Default Low Oil Pressure 1997 XK8
Was about to pull out from a parking lot, engine cuts out, "low oil pressure" light came on. Had it towed to my mechanic, he will be looking at it today. Fingers crossed the engine is OK. Assuming this is an oil pump, any sources for the replacement other than eBay?
Thank you.
Old Jul 31, 2017 | 07:46 AM
hope nothing serious - try our forum sponsors - SNG Barratt's or jagbits - both offer forum members 10% discount
Old Jul 31, 2017 | 08:58 AM
RJ237's Avatar
If the oil pressure light came on after the engine stopped, that's normal.
Old Jul 31, 2017 | 09:05 AM
reko19's Avatar
Yep, that is exactly how it happen. Engine stopped and then the light came on. I am waiting to hear from the mechanic, expecting it to be an oil pump. Found some options on eBay, will reach out to you guys to make sure I am ordering the right part once I hear back. Incidentally, how hard is it to replace the pump, is it more or less easily accessible?
Thx
Old Jul 31, 2017 | 09:22 AM
Mikey's Avatar
You're getting way ahead of yourself on several levels. The low oil pressure light came on as a result of the engine stopping, it was not the cause of the engine stopping.
All cars do this.
Old Jul 31, 2017 | 10:26 AM
TreVoRTasmin's Avatar
I do have what should be a pretty low mileage 97 motor that I got from a parts XK after I got a little too close to a deer. The car had 130k on the odo but it is a jaguar remanned so I would assume it would have a good deal less mileage. If the mechanic finds the worst you might be able to pry it out of my hands. Never heard it run but the car was dead from a bad tranny when I got it so would suspect it is just fine but I would do tensioners before installing it. LOL
Old Jul 31, 2017 | 10:53 AM
RJ237's Avatar
Thx
It would appear there is nothing wrong with the oil pump. As I wrote earlier, it's normal for the light to come on when the engine stops. Just stop an think: if the engine isn't running the oil pump isn't turning.
I hope your mechanic can determine why the engine quit, that's more to the point.
Old Jul 31, 2017 | 03:17 PM
reko19's Avatar
Just talked to my mechanic. He is scratching his head. Said the car is full of oil, oil is clean, he doesn't think it is an oil pump, but he can't get the car running. He is also having hard time hooking up his computer. I told him that I turned AC on 15 sec before it happened, he said that the AC is currently off. Any ideas?
Old Jul 31, 2017 | 06:04 PM
Only 3 essentials required to start the engine:
1. rotation
2. fuel
3. spark
Now your mechanic has apparently eliminated (1), it could be time to check for (2) ....
Old Jul 31, 2017 | 06:58 PM
reko19's Avatar
I dont think it is quite that simple, could be a computer issue, etc.
Old Jul 31, 2017 | 07:32 PM
RJ237's Avatar
Stop trying to make it more complicated, although it is a Jag. If your mechanic can't check for fuel pressure at the rail and spark you need a new mechanic.
Also since it's a nikasil lined engine, any attempts to start it cold without success could result in bore wash if the fuel pump is working. Other engines can also have the same issue, but the early Jags are particularly susceptible.
Please keep us informed.
Old Jul 31, 2017 | 07:34 PM
RJ237's Avatar
The 97 ECU is more likely to have a ECU failure due to leaking copacitors, but the typical symptom is a misfire of four or more cylinders and some strange fault codes.
Old Aug 1, 2017 | 11:43 AM
DevonDavid's Avatar
More information would be helpful .................
Does car lock and unlock OK ?
Do all lights on dashboard come on when key is turned to position 1.
Does engine turn over (crank) when key moved to position 2.
With ignition on, and foot on brake, can you move the gearshift lever.
What sort of "computer" is your mechanic using ?
How old is the battery and what is the voltage ?
Is there any fuel pressure at the Schrader valve (like a tyre valve) at the front of the engine on the right-hand (looking from front) side ?
Old Aug 1, 2017 | 11:50 AM
reko19's Avatar
Yes
Yes
Yes
Yes
Not sure, Sunoco station, I could find out.
Replaced last month.
Will find out and report back.
Thank you for your help
Old Aug 1, 2017 | 12:05 PM
grantorino62's Avatar
It's at a "gas station" Get it out of there! You need a specialist to check crank and cam sensors assuming it has normal fuel pressure. Find an Indie British car shop. Check reviews of any shop before committing the car.
Old Aug 1, 2017 | 12:22 PM
reko19's Avatar
I have been using them for a very long time. If can't figure it out he will tell me but so far he has been handling all my cars for the past 15 years including some pretty involved stuff. He checked the gas pressure, saying it is over 40 pounds holding pressure whatever that means.
Old Aug 1, 2017 | 01:35 PM
RJ237's Avatar
Okay, you probably have bore wash now on top of any previous problem. Have the mechanic check compression, it will probably be very low.
Do a search of bore wash on the forum if the compression is low and show the results to the mechanic. A small amount of oil in the cylinders is the cure.
Old Aug 4, 2017 | 09:24 AM
reko19's Avatar
Time for plan B, anybody could recommend a good Jaguar mechanic in Northern New Jersey, I am at zip code 07936. Car would have to be towed so distance is a consideration.
Thanks.
Old Aug 4, 2017 | 09:37 AM
jeremys's Avatar
Marotas Moters in Hawthorne NJ very good and I also know a very good ex jag mech who works out of his house near Sparta did major work on my car
Old Aug 4, 2017 | 09:45 AM
reko19's Avatar
Left a message for Marotas this morning, haven't heard back yet. I am ok with the ex jag guy if he is up to the challenge, if you don't mind please pm me his info. Thanks for your help.
