Is this a LRA1536BA vvt valve / solenoid?
Yes that is the VVT Solenoid but it is NOT LRA1536BA. That part number is for the VVT actuator for an AJ26 engine which is '97-'98. Your solenoid is part number AJ810570. The seal in question is part number AJ82856. Those don't normally cause too much trouble unless there is above normal crankcase pressure. I would take the little hose connector loose that is just to the right and above the solenoid in your picture and run small 1/8 inch drill bit into the cam cover. That will rod out a plugged part-load breather.
Cheers,
I agree, it is worth cleaning the part load breather, but I had a VVT seal go bad on my 4.2 S-type. You can just remove the VVT connector, pry the seal up gently with a screwdriver from the top and replace it....easy. The VVT solenoid and it's seal are totally separate parts.
Also, I think that the part Load Breather requires a 3/32" Drill to clean it.
My apologies, and thanks for the correction.
Cheers,
the superseded number, same part, is AJ810570 for AJ27. Constant (300 MgHz)variable frequency valve solenoid , unlike the on / off solenoid of the AJ26. I was hopeful the manufacturer would have a program flash to accept a wider response tolerance for these to avoid so many DTC issues.
I hope XJRguy is able to verify these numbers as his earlier post threw me a curve to try and figure out what was up. But all the solenoids laying on my desk currently were removed from a "1999' XK8 AJ27" and are imprinted with the old number above...
AJ26 VVT Solenoid
[on/off, looks like a hockey puck, plugs into engine timing cover]
Part #LCA1535AD, uses KSC145624 "O" ring seal
AJ27 VVT Solenoid -- like Gameblaster's picture
[fully variable, pokes through Cam Covers]
Part #AJ810570, uses AJ82856 seal
prior part numbers -- C2S4946, AJ84144, AJ82701
**LRA1536BA was apparently used in the S-Type 4.0L and SOME '00-'01 XK8's
but it became the C2S4946, and then AJ810570
Cheers,
