Is this a LRA1536BA vvt valve / solenoid?
Old Apr 25, 2011 | 02:09 PM
Gameblaster1's Avatar
Question Is this a LRA1536BA vvt valve / solenoid?
Hi Everyone,
I have oil coming out the edges of this on my engine. I am unsure of this part and proper replacement.
Attached Thumbnails Is this a LRA1536BA vvt valve / solenoid?-xk8-4.0la.jpg
Old Apr 25, 2011 | 03:23 PM
xjrguy's Avatar
Originally Posted by Gameblaster1
Hi Everyone,
**Note: See post #12 for clarification**
Yes that is the VVT Solenoid but it is NOT LRA1536BA. That part number is for the VVT actuator for an AJ26 engine which is '97-'98. Your solenoid is part number AJ810570. The seal in question is part number AJ82856. Those don't normally cause too much trouble unless there is above normal crankcase pressure. I would take the little hose connector loose that is just to the right and above the solenoid in your picture and run small 1/8 inch drill bit into the cam cover. That will rod out a plugged part-load breather.
Cheers,
Old Apr 25, 2011 | 03:37 PM
WhiteXKR's Avatar
I agree, it is worth cleaning the part load breather, but I had a VVT seal go bad on my 4.2 S-type. You can just remove the VVT connector, pry the seal up gently with a screwdriver from the top and replace it....easy. The VVT solenoid and it's seal are totally separate parts.
Old Apr 25, 2011 | 03:44 PM
xjrguy's Avatar
Right-O! What he said.......
Old Apr 25, 2011 | 03:46 PM
WhiteXKR's Avatar
VVT seal part number is AJ82856, $26 list.
Old Apr 25, 2011 | 04:33 PM
Paul Pavlik's Avatar
Hi Everyone,
Gameblaster: PM me with your address and I will send you (for free) 2 seals that I had left over when I did the Secondary Tensioner Job on my XKR (The XKR dosen't use the VVT).
Also, I think that the part Load Breather requires a 3/32" Drill to clean it.
Old Apr 25, 2011 | 04:40 PM
xjrguy's Avatar
Good man, Paul! Way to be.
Cheers,
Old Apr 26, 2011 | 04:20 PM
xjrguy's Avatar
What the he** is wrong with me? Correct, 2.5mm or 3/32" to clean out the part load breather. No idea why I gave the other figure; must be the beer!
My apologies, and thanks for the correction.
Cheers,
Old Apr 26, 2011 | 04:51 PM
BobF's Avatar
Wrap some tape around the drill bit end to keep it from dropping into the engine.
Old Apr 27, 2011 | 07:05 PM
mike66's Avatar
There's a baffle behind the hole so the bit can only go in so far unles the bit is real short.
Old Mar 6, 2014 | 05:47 PM
techtooltime's Avatar
Default LRA1536BA is the old number for AJ27
the superseded number, same part, is AJ810570 for AJ27. Constant (300 MgHz)variable frequency valve solenoid , unlike the on / off solenoid of the AJ26. I was hopeful the manufacturer would have a program flash to accept a wider response tolerance for these to avoid so many DTC issues.
I hope XJRguy is able to verify these numbers as his earlier post threw me a curve to try and figure out what was up. But all the solenoids laying on my desk currently were removed from a "1999' XK8 AJ27" and are imprinted with the old number above...
Old Mar 7, 2014 | 11:17 AM
xjrguy's Avatar
I see your confusion. Seems the parts catalog jumbles illustrations on some VIN ranges. My apologies.
AJ26 VVT Solenoid
[on/off, looks like a hockey puck, plugs into engine timing cover]
Part #LCA1535AD, uses KSC145624 "O" ring seal
AJ27 VVT Solenoid -- like Gameblaster's picture
[fully variable, pokes through Cam Covers]
Part #AJ810570, uses AJ82856 seal
prior part numbers -- C2S4946, AJ84144, AJ82701
**LRA1536BA was apparently used in the S-Type 4.0L and SOME '00-'01 XK8's
but it became the C2S4946, and then AJ810570
Cheers,
boiler
US Southwest
Dec 20, 2025 12:38 AM
redxk8
Oct 4, 2015 08:28 AM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
