Luggage Compartment Lights Not Working
Old Apr 28, 2025 | 10:56 AM
CMiller88's Avatar
Default Luggage Compartment Lights Not Working
Luggage compartment lights are not working. Replaced bulbs, checked wiring harness for broken wires, checked latch switch - appears to be functioning. Owner's manual doesn't specifically indicate which fuse for the trunk lights but I suspect they are connected to other interior/accessory lights which all seem to be working.
Old Apr 28, 2025 | 02:27 PM
does the glove box or your vanity lights work? From the electrical diagram 10.1 - looks like they all come from the same point on the BPM
http://jagrepair.com/images/AutoRepa.../jagxk1998.pdf
Old Apr 28, 2025 | 03:04 PM
Rex's Avatar
Rex
Probably the trunk micro switch. Easy job.
Old Apr 28, 2025 | 03:06 PM
CMiller88's Avatar
Thanks for the reply. Yes, both the glove box and vanity lights work. I checked other fuses as well. I also visually looked for any kinked, broken or frayed wires in the electrical harness. The trunk latch is working as well. Is there possibly a solenoid associated with the latch?
Old Apr 28, 2025 | 03:19 PM
CMiller88's Avatar
Rex, thanks for the response. Now where to find "how to change the trunk micro switch"? Any suggestions?
Old Apr 28, 2025 | 04:52 PM
Rex's Avatar
Rex
As I recall, just carefully remove the plastic trim piece at the back of the trunk (boot) and you will see it somewhere around the latching mechanism. Got replacement from Rock Auto or Welsh and it cured a host of gremlins.
Old Apr 28, 2025 | 06:17 PM
CMiller88's Avatar
Thanks, I'll give it a try.
Old Apr 28, 2025 | 06:18 PM
CMiller88's Avatar
justwant2drive
Feb 28, 2025 05:33 PM
Adworboys
Mar 11, 2023 12:00 AM
Harry Peter Rose
Mar 8, 2022 10:01 PM
Fairfalcon
Nov 1, 2017 04:17 PM
perfectphoto
Oct 27, 2011 01:50 PM
