moisture inside headlight compartment
Old Apr 1, 2013 | 11:38 PM
XKRoo's Avatar
Red face moisture inside headlight compartment
Would like to get rid of the moisture that has collected inside one of my headlight enclosure. Not sure HOW to remove the headlight bulb or? to gain access for a blow-drier... Any ideas on how a novice mechanic can accomplish it without breaking something (smile)?
Old Apr 1, 2013 | 11:43 PM
Frog's Avatar
Common problem: drill 1 or 2 8mm vent holes in the large transparent plastic cover on top of the headlight housing and then simply warm the glass from the outside with the hair dryer until the water has gone. The two holes should prevent 95% of the problem reoccurring in the future.
Old Apr 2, 2013 | 12:01 AM
Tirefriar's Avatar
A friend of mine on this forum has the same issue. My concern is wouldn't the drilled holes let water/dirt/dust in? Perhaps rubber plugs similar to those used by Paintless Dent Removal techs to plug holes they drill to access damaged panels from the inside?
Old Apr 2, 2013 | 12:08 AM
Sentinelist's Avatar
Also check the inner fender liner panels are still attached (and there). I had this issue, and a missing fender liner panel. Panel replaced, no more moisture.
Old Apr 2, 2013 | 12:21 AM
XKRoo's Avatar
Default Thanks for the prompt replies.
Will check the panel...and will think about drilling the holes then plug them after... Great support guys!!
Old Apr 2, 2013 | 04:49 PM
tberg's Avatar
XKRoo,
Since I bought my 2002 XKR about 3 years ago, I have always had a lot of moisture in the driver's side headlight but not passenger side til about a month ago. It then started on passenger side as well. Twice, I took a hair dryer, heated up the glass until the moisture disappeared, covered my car with its weatherproof cover for the night, only to find that by 6am the next morning, moisture had returned. Last Saturday, I went out to my car in the morning to find both headlights completely dry for the first time ever! It's been that way for the last 3 days, we had rain on Sunday (briefly), and still everything is dry. I have no idea what changed as I have made no alterations, holes. added silica gel or anything else. Magic!
Old Apr 2, 2013 | 04:58 PM
Blue XK's Avatar
I removed the top clear cover from the light units on mine and used it for a few weeks, the 3 mm of water that was sloshing in the light has gone and not even the slightest hint of condensation has returned.
My advice would be don't rush it or you'll end up needing a new light unit!
Old Apr 3, 2013 | 12:06 AM
XKRoo's Avatar
The panels are there... For starters I will remove the clear cover for a few days and see if that solves the problem...thanks again all who responded.
Old Apr 5, 2013 | 02:15 PM
Jimscriv's Avatar
My 98 developed the same problem, I removed the plastic covers, turned the lights on and went for a drive, a few miles later, no condensation. I haven't bothered to put the covers back on, but when I see condensation I just run the lights. No dust inside yet, but plan to drill and install easily removed plugs.
Old Apr 5, 2013 | 02:41 PM
malbec's Avatar
It's a standard Jag fix, my dealer did it for free...
Old Apr 6, 2013 | 12:29 PM
XKRoo's Avatar
problem solved... thanks to all who contributed information.
Old Apr 6, 2013 | 05:07 PM
Blue XK's Avatar
New lights? Drilled panels? Hair dryer? Or just whipped em out?
Old Apr 7, 2013 | 03:07 AM
XKRoo's Avatar
Had Jag of Tacoma do the mod...all OK
Jpav27
Sep 26, 2015 03:33 PM
VRB
Sep 15, 2015 08:18 AM
avern1
Sep 8, 2015 06:25 PM
user 652867429824
Sep 5, 2015 12:53 PM
laserguy
Sep 3, 2015 02:02 PM
