Most annoying thing about your XKR
Old Jan 8, 2017 | 04:16 AM
  #81
zecretw's Avatar
Thumbs up rise low beams
Originally Posted by lossking_
Not being able to see at night without high beams. Anyone know how to change headlights?
Hi.
In my adventures in rebuilding my XKR, I found out you can rise the low beams electrically. Modify the plastic thingi behind the low beam adjuster knob so you can turn it to a virtual "-1" instead of 0..3 will rise the beams more.
Remember to put it at 0 again when going for the inspection.
Regards
Old Jan 8, 2017 | 03:20 PM
  #82
scardini1's Avatar
That sounds interesting, Z - thanks. How do I get to the adjuster? Wheel well hatch?
Old Jan 10, 2017 | 03:22 AM
  #83
zecretw's Avatar
Hi.
No behind the adjuster knob.
there is a potentiometer there that can be rotated much higher than zero if the knob is removed. i know as i have removed the whole panel and relocated the adjuster potentiometer.
(A) in the image
XK8 instruction manual clip
Old Jan 26, 2017 | 07:20 PM
  #84
prettybluefin's Avatar
i bought a really deep, well made plastic dual cupholder for my XKR. it is wedged between the console and passenger seat, and slips out easily and is less than $8.00
https://www.amazon.com/TSI-Products-.../dp/B0009N4F6I
i "broke" the original XKR cupholder as it was useless, and missing one spring... and now use that to hold my phone while driving
Old Jan 26, 2017 | 07:23 PM
  #85
oh, and getting in and out of a coupe with 5" ground clearance in 5" heels on is quite a workout. but worth it!
Old Jan 27, 2017 | 12:33 AM
  #86
Thomas Kerr's Avatar
The broken left motor mount. Floppy v8 no good! Nearly dented the underside of the hood She's on the rack awaiting a new set as I type.
Old Jan 28, 2017 | 10:12 PM
  #87
scardini1's Avatar
So the knob is behind the Stability Control Button cover? How do I get the button cover off to reach the knob?
Originally Posted by zecretw
Hi.
(A) in the image
Old Apr 3, 2017 | 01:18 PM
  #88
Wide_Tyres_2's Avatar
Hey Prettybluefin,
looked at it on amazon... seems like a cool fix, but does it cover some of the passenger seat?
or please post a pic
Many Thanks
Andy
Old Apr 3, 2017 | 01:38 PM
  #89
scardini1's Avatar
Currently the most annoying thing is when the PAX door thinks it's open after I close it. Thankfully the interior lights don't stay on, but I constantly have to nudge the window closed, and I cannot lock the car.
Old Apr 3, 2017 | 04:54 PM
  #90
Originally Posted by Wide_Tyres_2
Hey Prettybluefin,
Many Thanks
Andy
just barely. not a bother to the passenger at all. I use the center well if only holding one cup as it's more snug. I love that I can just lift it out in a second and toss in the back when not in use.
  #91
Om28v's Avatar
The drip on the left leg when it is raining and you put the window down...even an inch.
Having to park at the far side of the parking lot to avoid dings.
The thought that no matter how hard I try, the car may not last forever.
I'm willing to suck it up.
Old Apr 4, 2017 | 03:07 PM
  #92
BlooDSMeaR's Avatar
After owning my car for a little over a month, I have found the most annoying thing to be is the next repair. As soon as I get one thing fixed there are two things else that pop up.
Old Apr 4, 2017 | 03:34 PM
  #93
cupholder fully loaded, and i store my phone charger in the old space where the original cupholder was.
Old Apr 4, 2017 | 05:25 PM
  #94
ObscureDave's Avatar
Lack of a front license plate bracket. Constantly paranoid that I will be ticketed and have to prove to a judge that I have complied by mutilating my front bumper with a Jed Clampett, chewing gum/bailing wire installation.
Never understand how with 26 states requiring a front plate, all vehicles don't have them as standard?!
Old Apr 4, 2017 | 06:13 PM
  #95
pwalsh691's Avatar
because a front bracket on an X100 would be a crime against humanity ;-)
Old Apr 4, 2017 | 08:06 PM
  #96
I drilled a couple of holes in the plate and mounted low with a course tread screw in the holes that were there from the original plate holder and then with a couple of chrome screw caps finished...bent the plate to contour the bumber... done and legal as it is a $170 fine here in BC
Old Apr 4, 2017 | 09:00 PM
  #97
Default Amen!
I hear you! Personally, I can convince myself that either with or without can look okay. But if a front plate is present I want it to look "factory"; that the placement was aesthetically planned.
Old Apr 4, 2017 | 09:04 PM
  #98
Default Hmmmm!
Interesting solution. I need to mull that one over. Thanks very much!
Old Apr 5, 2017 | 09:22 AM
  #99
theweeb's Avatar
hard to really see from this pic, but I did the same, mounted as low as possible as to not obscure the amazing wonderful front end. A couple of thin bolts/washers/nuts.
Bash
May 15, 2016 08:37 AM
dw9489
Dec 29, 2015 07:46 AM
scooby73
Dec 28, 2015 12:41 PM
jacob11379
Dec 26, 2015 01:57 PM
x42bnx
Dec 23, 2015 07:45 PM
