Moving oil cooler
Old Jan 15, 2020 | 02:22 PM
davidwin's Avatar
Default Moving oil cooler
Hi all,
My 04 XKR oil cooler was damaged by being scraped and needs to be replaced. I recall seeing a video showing how the cooler could be mounted higher and this may help to avoid do this again. I can't find it. Does anyone know where I can find it?
Thx,
Old Jan 15, 2020 | 08:03 PM
zray's Avatar
on my '02 XKR, the cooling system is all in very good condition Nevertheless, occasionally the coolant temperature is higher than I am comfortable with.
I would be worried that moving oil cooler higher would adversely affect air flow over the radiator.
Z
Old Jan 16, 2020 | 08:57 AM
fmertz's Avatar
FWIW, take a look at your ride height, as this could be a sign of collapsed upper shock mounts or lower shock bushings. Cooler is likely where it needs to be. Go to jagrepair.com, find the vehicle spec book, and measure the distance between the top of the wheel arch and the center of the wheel. Low ride height also bring excess negative camber and associated inner edge tire wear.
Best of luck, keep us posted.
Old Jan 16, 2020 | 09:56 AM
JayJagJay's Avatar
Originally Posted by davidwin
Hi all,
Thx,
IIRC I have heard that the oil cooler can just be turned over and possibly mounted the other way around. Higher. I read these damn forums so much, that I might be thinking about the Porsche 928 cooler... Hmm, bit now that I think about it, on mine, the cooler is built into the rad. Take a look. I think the mounts (I think they are rubber shocked bolt design) might allow for some movement,,,, upwards..
Old Jan 16, 2020 | 10:02 AM
JayJagJay's Avatar
Yeah... This dude in another thread talks a bit about mounting the cooler. You can see from his it is possible to have it above the bottom of the rad line... There is room for play in there, I'm pretty sure.
Old Jan 16, 2020 | 01:04 PM
mhminnich's Avatar
I built some standoffs and raised it a couple inches higher after my daughter crushed the first one.
Don't completely disconnect the lines on the cooler or you'll have a devil of a time trying to realign them.
I also tweeked the solid line to relieve some of the tension on the hoses.
Old Jan 16, 2020 | 05:11 PM
davidwin's Avatar
Thank you very much. I wills do this right away
Shahar Alon
Jul 2, 2019 03:23 AM
scardini1
Jan 12, 2015 01:58 PM
thefixer
Jan 1, 2015 11:07 AM
Skid Mark
Sep 15, 2011 01:06 PM
Grendel
Sep 29, 2010 04:00 PM
