Mystery wire, passenger side, rear
Old Sep 19, 2019 | 09:05 PM
crbass's Avatar
Default Mystery wire, passenger side, rear
I was digging in the rear passenger side looking at the hydraulic hoses and pondering a speaker replacement when I noticed a wire, comes from the rear and stops right before the beam that supports the front passenger seat belt. It stops abruptly in space, but has its own bracket, suggesting it is not a mistake of some sort. Anyone know what this is (thermocouple, something that should be attached to something else, etc)?
Wire that goes nowhere.
Old Sep 20, 2019 | 02:59 AM
DavidYau's Avatar
Default I have the same loose wire in rear quarter
I have the same. I think it’s for some rear occupancy sensor (maybe security/Airbag related). I did put a multimeter on it.... nothing.
I guess they run the same wire harnesses so without the options, that leaves alot of loose end connectors. I have quite a few under the centre console too.... no phone, no premium amp etc
Old Sep 20, 2019 | 06:48 AM
is that the sensor that keeps the top from operating above a certain speed?
Old Sep 20, 2019 | 07:48 AM
crbass's Avatar
The multimeter result is interesting. I didn't want to disturb the end, in case it was something crucial I didn't understand. So chalk it up to something I don't have, perhaps.
Old Sep 20, 2019 | 07:49 AM
crbass's Avatar
Is that a thing here? Speed feedback loop on the top?
Old Sep 20, 2019 | 08:27 AM
fmertz's Avatar
Key fob antenna? Just guessing.
Old Sep 20, 2019 | 08:45 AM
motorcarman's Avatar
fmerts, you are correct.
That is the SLCM receiver antenna for the keyfob transmitter.
Old Sep 20, 2019 | 08:56 AM
crbass's Avatar
Just saw motorcarman's post confirming right after I finally found it on the electrical diagrams with fmertz's guess. Thanks y'all. Curiosity sated, cat not dead.
Fob antenna in upper right hand corner.
user 652867429824
Oct 16, 2015 12:32 AM
jhxj6
Feb 3, 2012 01:44 PM
albackuk
Dec 24, 2011 07:26 PM
jag79
Apr 3, 2011 01:18 AM
