Nav system thinks I’m in Canada
Old Oct 6, 2019 | 10:57 AM
giandanielxk8's Avatar
Default Nav system thinks I’m in Canada
The screen in my nav system in my XKR had delaminated and needed to be replaced. It was completed unreadable.
As SamtheSham was going about his conversion to the 3 gauges, I sent him a PM asking if he was willing to sell his. For a modest amount and a Piña Colada the deal was agreed and he sent me the screen. I finally had some time to install it today. The unit is in immaculate conditions and works perfectly. (Thanks Sam!)
However, even though I know the system should be terribly outdated, I would at least like to have it working as it should.
Imagine my surprise when it seems the gps thinks I’m in Toronto Canada instead of Puerto Rico and does not display anything on the map other than the cursor.
Does anyone know how I can set it to the correct location?
Old Oct 6, 2019 | 11:55 AM
motorcarman's Avatar
I did PDIs when I worked at the dealer. The cars came from Coventry and when the NAV system 'woke-up' here in Texas, it did NOT know where it was.
I don't remember exactly what I used to do but I think I would scan out to the entire continental US and then move the location pointer to Fort Worth TX and then maybe reboot the system?
It's been more than 15 years since I did these cars but if you play around with the settings you will eventually get to to the correct location IF the correct DVD is in the unit.
You might find yourself driving on NOTHING with roads next to you if the DVD is outdated and NEW roads have been built??
Sorry I don't remember the exact sequence. Been too long.
bob
Old Oct 6, 2019 | 01:07 PM
DavidYau's Avatar
Default Why did he convert to 3 Gauges?
Maybe you found the reason Samthesham converted to a 3 gauge set up. LOL!
As smartphones are so good nowadays, car satnav systems are a bit obsolete esp. ones with built in DVDs. Even my rental cars nowadays have continual updates to a portable unit. Whatsapp’s Shared Location on google maps is a Genius invention... and free!
Maybe time to follow Samthesham’s example.
Old Oct 6, 2019 | 01:47 PM
David, I only swapped the screens, not the entire system. It was definitely doing this behavior before I put in Sam's screen. I vaguely remember playing with it when the screen was a little bit more readable and I think by then it already had the Canada location problem.
Motorcarman, by scan out, do you mean zoom out? I'll check the DVD, I don't know which one is in there.
Old Oct 7, 2019 | 03:41 AM
dibbit's Avatar
I had the same problem with my OEM sat nav - it was working fine but the map data didn't exist for Spain. My solution was to replace the OEM sat nav with a Garmin 5.2" unit - you can now get a 5.5" Garmin which is very near the exact same screen size as the OEM. You will get an up to date modern touch screen sat nav, with speed camera warnings and a back up camera if you want. On mine I kept the original buttons, connected up the backlights so they come on with the rest of the dashboard and wired the on/off switch to power the Garmin. All the connections were made to the original wiring harness using the connector from the OEM satnav.
Old Oct 7, 2019 | 09:07 PM
Got the system to change its location to Florida, but that is still wrong. I wondered why Puerto Rico wouldn’t show up. When I checked in the trunk, there is no DVD inside the DVD player.
Well, at least I now have a nice digital analog clock.
Does anyone know if it’s possible to download the software and rip it to a DVD?
Old Oct 8, 2019 | 10:29 AM
dsd's Avatar
dsd
Yes you can get the iso and download and burn. If you have issues PM me, I can assist.
Old Oct 8, 2019 | 06:07 PM
Perfect, that is easily within my skill set. Just point me to a download link for the ISO and I’m good to go.
Old Oct 8, 2019 | 07:08 PM
dsd's Avatar
dsd
https://www.jaguarforums.com/forum/x...e6/#post550533
Read the entire thread if you have any issues.
Old Oct 10, 2019 | 09:36 PM
Thanks! I'm burning the image as we speak. I'm using the slowest speed that macOS allows. I will report back with the results.
Old Oct 10, 2019 | 10:14 PM
Well, I tried the new DVD and the system updated. However, unfortunately for me, it does not include Puerto Rico. Perhaps I need a latin america version of the iso. Does anyone know where I can find that?
RGPV6S
Jul 31, 2018 10:39 PM
flyc2c
Dec 2, 2017 08:17 PM
Staatsof
Jun 14, 2010 03:23 PM
o2manyfish
Jun 4, 2010 09:19 PM
flann02x
Jun 16, 2008 06:27 PM
