Need info on missing trunk panel mount
Old Jan 16, 2023 | 05:10 PM
JAG8GUY's Avatar
Default Need info on missing trunk panel mount
the forward trunk panel of my 2004 XK8 is loose and warped -appears to be missing
a mounting strip or clips or? there are 2 slots in the sheet metal panel behind the carpeted panel
that look like they may be mounting points ?
Prethanks for any advice or help
Old Jan 17, 2023 | 02:29 AM
Pistnbroke's Avatar
WTF is a forward trunk panel? Photo please
Old Jan 17, 2023 | 08:13 AM
JAG8GUY's Avatar
Its the vertical panel behind the back seat steel support
Old Jan 17, 2023 | 08:19 AM
Markmbaha1's Avatar
Be aware, the gas tank is vertical between the back seat and trunk space so don't go drilling into it.
Old Jan 17, 2023 | 08:59 AM
JAG8GUY's Avatar
Good to know! thanks for that info! the vertical steel panel behind the carpeted panel is painted blue so i assume I could drill into that
to use a few short screws?
Old Jan 17, 2023 | 09:43 AM
Markmbaha1's Avatar
Default Gas tank location.
Here is the location on an early XK8.
yours may have modifications.
Old Jan 17, 2023 | 10:03 AM
JAG8GUY's Avatar
wow! my 2004 is not like this..behind the carpeted panel is a steel header panel painted same color as the body
Question still remains...what holds that carpeted panel un a vertical position ?
Mins is sagging and warped
Old Jan 17, 2023 | 10:47 AM
michaelh's Avatar
The car in the video above is a coupe. As you have found, there is an extra panel on the convertible. Please add the extra detail to your sig.*
On the coupe, the rear trim is 'held' by the trunk side trims and some strips of velcro attached to the fuel tank restraining straps. Looking at picture #3 in the tutorial on member Gus' site:
JagRepair.com - Jaguar Repair Information Resource
there seem to be a couple of similar strips attached to the metal panel you have in front of the tank itself.
It's a bit of a half-hearted effort, TBH. The velcro isn't really up to the job, and neither is the glue used to attach it
*edit: Signature is accessed via 'User CP' on top LHS of page, scroll down to 'Edit Signature'
Old Jan 17, 2023 | 12:18 PM
JAG8GUY's Avatar
thanks for all that info..as a new owner I had no clue.
I am afraid since the panel is warped velcro may not hold it in place
I was considering using some nice chrome sheetmetal screws with a counter sink bezel washer
I also have some OEM /GM black trim screws that would not show as much
There are 2 oval shaped slots in the metal panel on each end that look like
mounting points for the carpeted panel?
drbill
Jun 4, 2018 06:09 PM
Joanie
Jan 25, 2018 09:31 AM
Cruzer56
E type ( XK-E )
May 18, 2016 06:30 PM
cbharley10
17
Feb 7, 2013 12:32 PM
mechelement
Aug 28, 2012 10:00 AM
