Need info on mystery tube?
Old Oct 26, 2012 | 09:37 PM
nherndonxk8's Avatar
Default Need info on mystery tube?
Ok, so whats the thin skinny plastic black tubing coming off the top of the round metal canister on top of the throttle body ...it snakes its way around to to the passenger side of the engine bay and disappears into the sidewall and goes where???mine is really brittle....is this some type of vacuum tubing????
thanks
Old Oct 27, 2012 | 03:59 AM
thanks
Does the Actuator Vacuum Pipe (item 14) look right for this?
Old Oct 27, 2012 | 05:56 AM
RJ237's Avatar
It ends up in the fender well where the three vacuum solenoids are located. Remove the liner ( careful, very expensive) and it will be obvious. If that is brittle, chances are the vacuum line from the engine should be replaced also
Old Oct 29, 2012 | 11:23 AM
Yes number 14 is the line
Old Oct 29, 2012 | 12:32 PM
Paul Pavlik's Avatar
This is the Vacuum line to the Cruise Control Servo.
Old Jun 19, 2019 | 03:33 PM
Paul Crawford's Avatar
Thank you for this post. I’ve been racking my brains as to where this goes. As I have just about 3 inches of pipe coming out the actuator. But no other pipe visible my guess is it’s slipped down behind the wheel arch cowling. So some new tubing to buy and fit.
Old Jun 19, 2019 | 05:35 PM
frankc's Avatar
Good luck! You may well find its not available anymore.
Old Jun 19, 2019 | 07:42 PM
michaelh's Avatar
If, like me, you don't have cruise, then the pipe doesn't do anything and is just tucked away:
https://www.jaguarforums.com/forum/x...2/#post1243815
Poet
Feb 7, 2025 02:18 PM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
mrplow58
Sep 30, 2015 08:56 AM
Rocky15
Sep 28, 2015 04:59 PM
