OBD2 wont communicate with my car
Old Apr 20, 2014 | 04:21 AM
zecretw's Avatar
Post Maby some help.
Originally Posted by jaglenn
P1000 OBD Systems Readiness Test Not Complete
P1637 CAN Link ECM/ABS Control Module Circuit/Network
P1638 CAN Link ECM/INSTM Circuit/Network
P1642 CAN Link Circuit
P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network
Looks to me like it's saying the CAN is screwed.
But it is doing more now that it has since I got the car.
Some life is better than none!
The CAN by definitionis is quite ridgid and it only seems it cant find it's pals on the network.
Check the CAN wires, it should be about 60 ohm resistance. If it is infinite or zero you have a bad wire. If its 120 ohms one side of the bus is bad. I'm not sure which modules are at the end of the bus with the terminator resistors inside. But if they are not there it wont work. As all modules are lost this would be my first check.
See this thread from somewhere else.
CAN Physical Layer and Termination Guide - National Instruments
Good luck!
/Daniel
Old Apr 20, 2014 | 03:07 PM
JagV8's Avatar
I don't know on this jag but on the S-Type with CAN (so, 2003+) the terminators are in the PCM (aka ECM) and the ICM (dash aka cluster).
With one water-damaged PCM what is/are the other(s) like? Is the PCM connector good (clean, dry, lithium grease etc)?
You can take modules off the bus if need be so long as if you take one with a terminator off you add your own terminator (120 ohm resistor).
Old Jun 2, 2014 | 10:32 PM
Padrino's Avatar
And what has been the final resolve to the communications problem?
I'm facing the same and before I spend a lot of time...and $$$, I'd like to know what others have experienced.
Old Jun 3, 2014 | 11:26 AM
jaglenn's Avatar
I had to change the ECM due to water damage... in order to get mine to communicate. I also just now got back from having the ECM immobilizer programed.
Thanks to Avenue Garage in Port Charlotte FL
Old Jun 3, 2014 | 11:48 AM
Padrino's Avatar
Default Graham, your fuse diagram is for what car?..
Originally Posted by GGG
Both DLC fuses OK and your scantool known to work on XK8/XKR?
Attachment 80714
Graham, your fuse block diagram shows 2 power sources for the OBD but all the other fuse block diagrams I've located, including my drivers manual, shows only 1. What car is this for? I'm chasing easy solutions at this point.
Old Jun 3, 2014 | 01:45 PM
jaglenn's Avatar
she lives!!!!
The motor runs.. have to tach it really high to get any motion out of it. I let it warm up and fluids circulate. It feels like there is no fluid in the transmission
Old Jun 8, 2014 | 11:47 AM
Padrino's Avatar
I got lucky!!!!
Turned out to be the smog station's reader was the problem. Took my Jag to the local Jag mech that's always worked on her and his OBD2 reader could connect. Took the car to a smog station of his recommendation and it passed fine.
Happy day!
Old Mar 5, 2024 | 01:47 PM
  #28
JagV8's Avatar
Or - and this is common - the OBD tool is only mostly working (and its software fails on a Jaguar).
Old Mar 5, 2024 | 03:17 PM
RJ237's Avatar
But geteh has a Corvette. We don't get to troubleshoot many Corvettes here.
Maybe the Honda protocol is not the same and the scanner setup needs to be changed.
Old Mar 6, 2024 | 11:51 AM
  #30
Geraldius's Avatar
I've had 3 out of 5 perfectly good OBD2 scanners that could not communicate with my 2000 XK8. Of the two that did work, one was too dumb to provide the detailed info that I needed and the other was a bluetooth OBD2 dongle that transmits the data to a PC or tablet that runs various OBD2 diagnostic apps. Something is odd or non-standard about the OBD2 on this Jag.
So you might try another different model scanner.
Old Mar 7, 2024 | 03:05 AM
  #31
JagV8's Avatar
Odd, yes. (But obeys the standards.)
And that's the fix.
jim_63219
May 18, 2023 08:25 AM
Bruiser
Jan 9, 2019 09:55 PM
Mountaineer
May 6, 2017 02:17 PM
AL NZ
Jun 10, 2016 02:18 PM
Faycal Moumouni
Apr 23, 2016 06:35 AM
