odd plate on front underside
Old Apr 29, 2012 | 11:13 AM
RaceDiagnostics's Avatar
Default odd plate on front underside
Has anyone had to replace this plate before?
Is it original, if yes what is the point of it?
Can it be removed, or does it need to be cut out?
Looks like there is something missing from the two circular grippy things, anyone know what?
Jim
Old Apr 29, 2012 | 12:59 PM
Is that the front floorpan?
Jaguar World magazine reported 'the XK8/XKR is vulnerable to corrosion of the front floorpans where a plate - possibly used during manufacture to mount the body onto its cradle - traps moisture and can rust right through into the footwell; when repairing it is important to eliminate the plate and thus the cause of the problem.'
Old Apr 29, 2012 | 01:28 PM
GordoCatCar's Avatar
Those circular grippy things are snap in disc covers used to fill holes in the floor panels. The tangs hold the covers in place.
Old Apr 29, 2012 | 02:10 PM
The Coupe's Avatar
These plates are of the devil. The passenger side plate is the ONE place on my entire car where there is some corrosion of the body itself. My hope is to have both plates removed and the corrosion repaired this summer.
All XK8 / R owners should be aware of these potential trouble spots. According to XKRacer, two more potential trouble spots reside in the boot, underneath the carpeted panels on the right and left sides. There is a rectangular vent on both sides (both vents face toward the rear fenders), made of plastic, with a little rubber / flapper door. These vents are the "exit" for outside air coming into the car through the ventilation or AC system. Over time, debris from the road can collect around the little rubber doors, holding them open a bit. Then water can get in, splashed up from driving in the wet, and the water collects below the vent. Corrosion soon follows.
Old Apr 29, 2012 | 03:36 PM
I will try to chisel it off and see what lies beneath....
Old Apr 29, 2012 | 05:11 PM
NikasilNik's Avatar
Hi RD ,
If you chisel the plate off you will find no doubt there is a rust hole underneath , the plate was put there by Jaguar to mount the body shell while it was on the production line , to effect a proper repair the seats , carpets and centre console need to come out , the floor pan where rusted cut out and a new section shaped and welded in ,
Hope this helps ,
Nik
Old Apr 30, 2012 | 02:58 AM
What a pain in the ar...
I had to do this all a year ago on my 450SL, seats out, carpets out, centre console out.
After
Old Apr 30, 2012 | 03:15 AM
.........but much better than the dark days of the 1970's when XJ6's dissolved from the ground up in less than five years courtesy of a combination of dreadful build quality and road salt.
Old Apr 30, 2012 | 04:49 AM
dennisw's Avatar
wouldnt do that..look under the carpets first..if ok leave well alone..looks ok to me..
Old May 1, 2012 | 07:42 AM
lorwood's Avatar
I would inspect from the inside first. A visual inspection along with some poking around with a screw driver. If all seems well I would clean up the area both inside and from underneath. Sand down any surface rust and treat with a rust converter and then inhibitor. Eastwood makes some great products for these situations. Finally I would use a seam sealer (also can be purchased from Eastwood) between the plate and the undercarriage.
I am going to inspect and hope to find no real problem as of yet and then take these preventative measures.
And then stop driving in the rain and snow.
Old May 1, 2012 | 08:08 AM
dennisw's Avatar
I had a 1972 xj6 but it wasnt that bad..should have seen my 1959 cresta...that was a rust box
Old Sep 9, 2012 | 02:53 PM
Took a short cut today to buy some time, its been dry here for a week or so so got underneath with the shot blaster and cleaned up both sides then smuthered in waxoyl underseal.
Old Sep 9, 2012 | 05:48 PM
H20boy's Avatar
that repair is looking sooooo much better than a plate welded onto the body!
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
user 652867429824
Oct 28, 2015 10:18 AM
tberg
Sep 17, 2015 10:43 PM
